My problem is resolved by using the following JVM flag:
-Doracle.jdbc.mapDateToTimestamp=false
This restores the legacy mapping of DATE to sqlType 91 instead of 93 and as a result GeoTools will not expect time to be supplied with date and will not output time when writing a date as a string.
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Sent: Wednesday, May 10, 2017 12:23 PM
To: Walter Stovall <walter.stovall@anonymised.com>
Cc: geoserver-devel@anonymised.comsourceforge.net
Subject: Re: [Geoserver-devel] Oracle DATE treated as TIMESTAMP makes WFS handle the value incorrectly when using a VTABLE
On Wed, May 10, 2017 at 6:15 PM, Walter Stovall <walter.stovall@anonymised.com> wrote:
fwiw this looks more like a problem with the Oracle driver than GeoTools. The sqlType=93 is Timestamp as represented by the ResultSetMetadata but it seems like it should be sqlType=91 (Date). I’m looking at how to make GeoTools handle a work around for this Oracle issue.
Yes, if you check the archives of geotools/geoserver there has already been a discussion about it, but
not resolution (usual stuff, when a commercial component is in the mix like Oracle, only paid support
is active, nobody is going to move a finger in their spare time for it).
When you have a solution do a pull request following the GeoTools contribution rules:
https://github.com/geotools/geotools/blob/master/CONTRIBUTING.md
(in short, add a test, make sure your added code is properly formatted but don’t reformat
code you did not modify).
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
