[Geoserver-devel] Oracle Georaster support
The imagemosaic-jdbc module adds Oracle Georaster support without using an Oracle Specific API. No problems with the build process , at runtime , only the oracle jdbc driver has to be in the class path.
Geoserver documentation is here
http://docs.geoserver.org/stable/en/user/data/oraclegeoraster.html
Geotools documentation is here
http://docs.codehaus.org/display/GEOTDOC/Oracle+GeoRaster+Plugin
Should I make an announcement on the user lists ?
This message was sent using IMP, the Internet Messaging Program.
Imho it's worth a blog post :slight_smile:
If you're shy you can create a draft of it, send it to the list,
and we can probably review and post it.
Otherwise we give you access, you create the blog post, someone
reviews it, and then we publish it.
Andrea Aime
OpenGeo - http://opengeo.org
You mean something like that
http://geotoolsnews.blogspot.com/
Upps, I have never done this before :slight_smile:
Anyways, its time to learn it. I have a google account, but I do not see the geotools blog.
For geoserver, the blog looks different, and I cannot login.
Quoting Andrea Aime <aaime@anonymised.com>:
Andrea Aime
Let me invite you as a blog contributor;
accept the invite and try again.
Jody
path.
Andrea Aime
Geoserver-devel mailing list
No invitation so far. I assume I will receive a mail ?
Quoting Jody Garnett <jody.garnett@anonymised.com>:
Jody
path.
Andrea Aime
Not sure how it shows up; you may of filtered it or something as it will come from blogger.
Jody
Jody
path.
Andrea Aime
Nope it looks like I just added you; sign into blogger and write.
Jody
Jody
path.
Andrea Aime
