[Geoserver-devel] oracle spatial data store [SEC=Unclassified]
Visram, Kassim wrote:
hi miles--
thanks for the response
i sent an email to justin earlier today (attached) with the output of geoserver startup
and a log file)
i've also just followed your suggestion and removed classes12.jar from the lib
  directory and from my CLASSPATH in the startup command: /usr/java/bin/java
-DGEOSERVER_DATA_DIR=$GEOSERVER_DATA_DIR -Djava.awt.headless=true -DSTOP.PORT=8079
-DSTOP.KEY=geoserver -cp
   $GEOSERVER_HOME/lib/ojdbc14.jar:$GEOSERVER_HOME/gt2-oracle-spatial-2.3.1 .jar -jar
start.jar | tee -a geoserverstart_6oct_2.txt (i'm attaching that file as well)
but still cant see Oracle Spatial in my list of available DataStores
cheers
--kassim
_____________________________________ ___
Ah ok...
http://java.sun.com/j2se/1.5.0/docs/tooldocs/solaris/java.html#-jar
"When you use [the -jar] option, the JAR file is the source of all user classes, and other user class path settings are ignored."
So in essence the -cp switch is being ignored in your startup command... But it should pick them up if you put them in geoserver's default lib directory anyway - "[GEOSERVER_HOME]/server/geoserver/WEB-INF/lib/"
Miles
PS- Questions like this should be posted to the geoserver-users group...
___________________________________________________________________________
    Australian Antarctic Division - Commonwealth of Australia
IMPORTANT: This transmission is intended for the addressee only. If you are not the
intended recipient, you are notified that use or dissemination of this communication is
strictly prohibited by Commonwealth law. If you have received this transmission in error,
please notify the sender immediately by e-mail or by telephoning +61 3 6232 3209 and
DELETE the message.
        Visit our web site at http://www.antarctica.gov.au/
