[Geoserver-devel] Oracle Spatial-NO connection error
Could you try it with instance instead of database?
And actually is TESTORA the name of the computer? Is the database
running on your computer? If so you should use 'localhost'
or '127.0.0.1', if not then try the actual ip of the computer instead
TESTORA, for the host parameter.
       Chris
Quoting Gautam Ganguly <ggangul@anonymised.com>:
hi Chris,
I made the loggingLevel FINER.On calling
http://localhost/geoserver/GetCapabilities , i see the oracle part
in
the Tomcat windows.I am just placing the Oracle part of the log which
i
hope helps you.
354900 [FINER] org.geotools.data.DataSourceFinder - Available Data
Sources:
354900 [FINER] org.geotools.data.DataSourceFinder - PostGIS spatial
database
354910 [FINER] org.geotools.data.DataSourceFinder - ESRI(tm)
Shapefiles (*.shp)
354910 [FINE] org.geotools.data.oracle.OracleDataSourceFactory -
oracle datasource factory constructed
354910 [FINER] org.geotools.data.DataSourceFinder - Oracle Spatial
Database
354910 [FINER] org.geotools.data.oracle.OracleDataSourceFactory -
canProcess called on {table=test_ora_layers, user=userme,
passwd=passme,
host=TESTORA, port=1521, database=TESTORA,
dbtype=oracle}
354910 [FINE] org.vfny.geoserver.responses.WfsException - could not
construct a datasource for topp:test_ora_layers with params:
{table=test_ora_layers, user=userme, passwd=passme, host=TESTORA,
port=1521, database=TESTORA, dbtype=oracle}
354910 [WARNING] org.vfny.geoserver.config.TypeInfo - Could not get
DataSource: topp:test_ora_layers during GetCapabilities: could not
port=1521, database=TESTORA, dbtype=oracle} returning basic
Capabilities, but GetFeature requests will likely fail.
354920 [FINER] org.vfny.geoserver.servlets.Capabilities - response
is
<?xml version="1.0" encoding="UTF-8"?><WFS_Capabilities
version="1.0.0"
   xmlns="http://www.opengis.net/wfs&quot;
   xmlns:cdf="http://www.opengis.net/cite/data&quot;
   xmlns:topp="http://www.openplans.org/topp&quot;
   xmlns:cgf="http://www.opengis.net/cite/geometry&quot;
   xmlns:ogc="http://www.opengis.net/ogc&quot;
   xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
   xsi:schemaLocation="http://www.opengis.net/wfs
http://localhost/geoserver/dat
a/capabilities/wfs/1.0.0/WFS-capabilities.xsd">
  <Service>
    <Name>FreeFS</Name>
    <Title>The Open Planning Project Basemap Server</Title>
    <Abstract>This is a test server. It contains some basemap data
from New Yor
k City.</Abstract>
    <Keywords>WFS. CITE. New York</Keywords>
    <OnlineResource>http://www.openplans.org/&lt;/OnlineResource&gt;
    <Fees>NONE</Fees>
    <AccessConstraints>NONE</AccessConstraints>
  </Service>
  <Capability>
    <Request>
      <GetCapabilities>
        <DCPType><HTTP><Get
onlineResource="http://localhost/geoserver/GetCapabi
lities?"/></HTTP></DCPType>
        <DCPType><HTTP><Post
ilities"/></HTTP></DCPType>
      </GetCapabilities>
      <DescribeFeatureType>
<SchemaDescriptionLanguage><XMLSCHEMA/></SchemaDescriptionLanguage>
        <DCPType><HTTP><Get
onlineResource="http://localhost/geoserver/DescribeF
eatureType?"/></HTTP></DCPType>
FeatureType"/></HTTP></DCPType>
      </DescribeFeatureType>
      <GetFeature>
        <ResultFormat><GML2/></ResultFormat>
        <DCPType><HTTP><Get
onlineResource="http://localhost/geoserver/GetFeatur
re"/></HTTP></DCPType>
      </GetFeature>
      <Transaction>
        <DCPType><HTTP><Get
onlineResource="http://localhost/geoserver/Transacti
on?"/></HTTP></DCPType>
ion"/></HTTP></DCPType>
      </Transaction>
      <LockFeature>
        <DCPType><HTTP><Get
onlineResource="http://localhost/geoserver/LockFeatu
re?"/></HTTP></DCPType>
ure"/></HTTP></DCPType>
      </LockFeature>
      <GetFeatureWithLock>
        <DCPType><HTTP><Get
eWithLock?"/></HTTP></DCPType>
reWithLock"/></HTTP></DCPType>
      </GetFeatureWithLock>
    </Request>
  </Capability>
  <FeatureTypeList>
   <Operations>
    <Query/>
    <Lock/>
   </Operations>
    <FeatureType>
      <Name>topp:road</Name>
      <Title>Random Road Centerlines</Title>
      <Abstract>This is some random road features</Abstract>
      <Keywords>road, New York City, TOPP</Keywords>
      <SRS>http://www.opengis.net/gml/srs/epsg#32118&lt;/SRS&gt;
      <LatLongBoundingBox minx="-74.27000" miny="40.50000"
maxx="-73.80000" maxy
="40.94000"/>
    </FeatureType>
    <FeatureType>
      <Name>topp:rail</Name>
      <Title>NYC Rail Centerlines</Title>
      <Abstract>This is a simple rail coverage from New York
City</Abstract>
      <Keywords>OWS1, rail, railroad, New York City</Keywords>
="40.94000"/>
    </FeatureType>
    <FeatureType>
      <Name>topp:test_ora_layers</Name>
City</Abstract>
="40.94000"/>
    </FeatureType>
  </FeatureTypeList>
  <ogc:Filter_Capabilities>
    <ogc:Spatial_Capabilities>
      <ogc:Spatial_Operators>
        <ogc:Disjoint/>
        <ogc:Equals/>
        <ogc:DWithin/>
        <ogc:Beyond/>
        <ogc:Intersect/>
        <ogc:Touches/>
        <ogc:Crosses/>
        <ogc:Within/>
        <ogc:Contains/>
        <ogc:Overlaps/>
        <ogc:BBOX/>
      </ogc:Spatial_Operators>
    </ogc:Spatial_Capabilities>
    <ogc:Scalar_Capabilities>
      <ogc:Logical_Operators/>
      <ogc:Comparison_Operators>
        <ogc:Simple_Comparisons/>
        <ogc:Between/>
        <ogc:Like/>
        <ogc:NullCheck/>
      </ogc:Comparison_Operators>
      <ogc:Arithmetic_Operators>
        <ogc:Simple_Arithmetic/>
      </ogc:Arithmetic_Operators>
    </ogc:Scalar_Capabilities>
  </ogc:Filter_Capabilities>
</WFS_Capabilities>
354940 [FINER] org.vfny.geoserver.servlets.Capabilities - response
encoding is
UTF-8
Hope that helps.
regards
Gautam
>>> <cholmes@anonymised.com> 11/28/03 12:37PM >>>
It looks like you're doing everything correctly. It should
definitely
be instance, not database, but if you've tried both then it should
work. I think the problem may be a classpath issue. If you could
turn your logging level to finer and start up geoserver, look for a
line like 'Postgis is an available datasource'. There should also be
two more lines: 'Shapefile is an available datasource' and 'oracle is
an available datasource' (I'm working off of memory here, might be
slightly different'. So look for those lines, and if the oracle one
is not there then that's probably the problem. If it is I can
probably fix it for you relatively easily (you just have to get the
servlet container recognizing the right meta-inf/service/Data...
line,
that tells which factories are available). If not then we'll have to
investigate further. Let me know and we can better diagnose the
problem. And thanks for the nice detailed message.
          Chris
> hi all,
> I am trying to make Geoserver to use oracle-spatial.When i use
the
> url:
> http://localhost/geoserver/GetFeature?typename=topp:test_ora_layers
> i get the following on my browser:
> <?xml version="1.0" ?>
> <ServiceExceptionReport version="1.2.0"
> xmlns="http://www.opengis.net/ogc&quot;
> xsi:schemaLocation="http://www.opengis.net/ogc
> http://localhost/geoserver/data/capabilities/wfs/1.0.0/OGC-
exception.xsd">
> <ServiceException>Please contact the admin, the configuration
for
> topp:test_ora_layers has
> an error. No datasource could be constructed with the params:
> user=userme, passwd=passme, host=TESTORA, port=1521,
> database=TESTORA, dbtype=oracle} from the
> info.xml file.</ServiceException></ServiceExceptionReport>
> I did notice the following message on the tomcat screen:
> 127853 [WARNING] org.vfny.geoserver.config.TypeInfo - Could not
get
> DataSource:
> topp:test_ora_layers during GetCapabilities: could not construct
a
> datasource
> for topp:test_ora_layers with params: {table=test_ora_layers,
> user=userme,
> passwd=passme, host=TESTORA, port=1521, database=TESTORA,
> basic Capabilities, but GetFeature requests will likely fail.
> My system settings are:
> OS-Win2000
> Database - oracle Spatial-1.1.7
> WebServer - IIS-5.0
> Tomcat-4.1.27
> Geoserver ver - 1.0
> As per the docs,i built Geoserver.war and also managed to
installed
> it
> under Tomcat.
> Calling the url http:\\localhost\geoserver\getcapabilities..i do
get
> the xml doc returned
> to me in the browser.
> As per the doc,to make it work with Oracle..i followed all the
> steps
> as mentioned there.
> I got the classes12.zip and sdoapi.zip from oracle and renamed
them
> to
> classes12.jar and sdoapi.jar and placed them into the
> c:\tomcat\webapps\geoserver\web-inf\lib dir.The oracle table has
the
> following table description:
> sql>desc test_ora_layers
> Name Null? Type
> LAYER_ID NUMBER
> SHAPE
> MDSYS.SDO_GEOMETRY
> I have the directory under \data\featureTypes\test_ora_layers,as
> mentioned in the doc.
> The datasourceparams tag inside the info.xml looks like these:
> <DatasourceParams>
> <host>TESTORA</host>
> <port>1521</port>
> <instance>TESTORA</instance>
> <user>userme</user>
> <passwd>passme</passwd>
> <table>test_ora_layers</table>
> <dbtype>oracle</dbtype>
> </DatasourceParams>
> The Schema.xml looks like these:
> <xs:complexType name="test_ora_layers_Type">
> <xs:complexContent>
> <xs:extension base="gml:AbstractFeatureType">
> <xs:sequence>
> <xs:element name="layer_id" nillable="false"
minOccurs="0"
> maxOccurs="1">
> <xs:simpleType>
> <xs:restriction base="xs:integer">
> <xs:totalDigits value="10"/>
> </xs:restriction>
> </xs:simpleType>
> </xs:element>
> <xs:element name="shape" type="gml:PolygonPropertyType"
> nillable="false" minOccurs="1" maxOccurs="1"/>
> </xs:sequence>
> </xs:extension>
> </xs:complexContent>
> </xs:complexType>
> Also in the doc,it is mentioned that in case of oracle,the
> DataSourceParams tag has a child node called <instance> and not
> <database>.Looking at the FeatureType.java,were these
> tags are read in the function getDataParams(..), i saw that these
> function looks for tag called <database>,so i even changed it from
> "instance" to "database" tag but that didnot help it either.
> Any help or suggestion would be highly appreciated.
> regards,
> Gautam
> This SF.net email is sponsored by: SF.net Giveback Program.
> Does SourceForge.net help you be more productive? Does it
> help you create better code? SHARE THE LOVE, and help us help
> YOU! Click Here: http://sourceforge.net/donate/
> Geoserver-devel mailing list
> Geoserver-devel@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
This mail sent through IMP: http://horde.org/imp/
