[Geoserver-devel] Oracle Spatial-NO connection error
Yes, looks like you solved the connection issue. For your next issue,
no, it's not because the schema.xml file is wrong, that would not
cause such an error. I'm going to have to defer to Sean on this one,
as he's the oracle expert. He will likely reply fairly soon, I think
we've seen this before, but I don't remember the solution. It's
probably something with how your oracle tables are set up.
          Chris
Quoting Gautam Ganguly <ggangul@anonymised.com>:
Chris,
  I think the connection issue is solved as soon as i changed the
tag
to <instance> from <database>.also the host tag has the ip-address
of
the database machine instead of the name.,Because now i see these
message:
80055 [FINER] org.vfny.geoserver.requests.RequestKvpReader - clean
request is
typename=topp:test_ora_layers
80075 [FINER] org.vfny.geoserver.config.ConfigInfo - returning
typeDir
C:\Tomcat\webapps\geoserver\data/featureTypes/
80075 [FINER] org.vfny.geoserver.config.TypeRepository - about to
read
types at
C:\Tomcat\webapps\geoserver\data\featureTypes
80085 [FINER] org.vfny.geoserver.config.TypeInfo - pathToSchema is
C:\Tomcat\w
ebapps\geoserver\data\featureTypes\test_ora_layers\schema.xml
80115 [FINER] org.vfny.geoserver.config.FeatureType - there are
nodes:
29
80115 [FINER] org.vfny.geoserver.config.FeatureType - setting
property
with 1.2.3.4
80125 [FINER] org.vfny.geoserver.config.FeatureType - setting
property
with 1521
property
with TESTORA
80135 [FINER] org.vfny.geoserver.config.FeatureType - setting
property
with userme
property
with passme
property
with test_ora_layers
80145 [FINER] org.vfny.geoserver.config.FeatureType - setting
property
with oracle
80145 [FINER] org.vfny.geoserver.config.FeatureType - [#text:] is
the
node and the name is null
80185 [FINER] org.vfny.geoserver.config.TypeInfo - params is
{table=fw_layers_3
216, user=userme, instance=TESTORA, passwd=passme, host=1.2.3.4,
port=1521
, dbtype=oracle}
80185 [FINER] org.geotools.data.DataSourceFinder - Available Data
Sources:
80185 [FINER] org.geotools.data.DataSourceFinder - PostGIS spatial
database
80185 [FINER] org.geotools.data.DataSourceFinder - ESRI(tm)
Shapefiles
(*.shp)
80185 [FINE] org.geotools.data.oracle.OracleDataSourceFactory -
oracle
datasour
ce factory constructed
80185 [FINER] org.geotools.data.DataSourceFinder - Oracle Spatial
Database
80185 [FINER] org.geotools.data.oracle.OracleDataSourceFactory -
canProcess cal
led on {table=test_ora_layers, user=userme, instance=TESTORA,
passwd=passme,
host=1.2.3.4, port=1521, dbtype=oracle}
create
ds
called in oracle
80196 [FINER] org.geotools.data.oracle.OracleDataSourceFactory -
canProcess cal
passwd=passme,
80306 [FINE] org.geotools.data.jdbc.ConnectionPool - No available
connections,
creating a new one.
81567 [FINE]
org.geotools.data.jdbc.ConnectionPool$ConnectionListManager -
Connection closed - adding to available connections.
81567 [FINE] org.vfny.geoserver.responses.WfsException - >
[test_ora_layers]:
  While getting connection to datasource:
org.geotools.data.DataSourceException:
SQL Error occured when generating unique key
81567 [FINE] org.vfny.geoserver.responses.WfsException - return wfs
exception
is <?xml version="1.0" ?>
<ServiceExceptionReport
   version="1.2.0"
   xmlns="http://www.opengis.net/ogc&quot;
   xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
   xsi:schemaLocation="http://www.opengis.net/ogc
http://localhost/geoserver/dat
a/capabilities/wfs/1.0.0/OGC-exception.xsd">
   <ServiceException locator="test_ora_layers">
   </ServiceException>
</ServiceExceptionReport>
I think you did help me with my database connection issue.Thank you
very much for that.
As per the error that i am getting ,do you think its being caused
because of incorrect type in schema.xml
for the oracle SDO_geometry object??Here is my schema.xml file
  <xs:complexType name="test_ora_layers_Type">
    <xs:complexContent>
      <xs:extension base="gml:AbstractFeatureType">
        <xs:sequence>
          <xs:element name="layer_id" nillable="false" minOccurs="0"
maxOccurs="1">
            <xs:simpleType>
              <xs:restriction base="xs:integer">
                <xs:totalDigits value="10"/>
              </xs:restriction>
            </xs:simpleType>
          </xs:element>
    <xs:element name="shape" type="gml:PolygonPropertyType"
nillable="false" minOccurs="1" maxOccurs="1"/>
        </xs:sequence>
</xs:extension>
</xs:complexContent>
</xs:complexType>
thanks again.
regards,
Gautam
>>> <cholmes@anonymised.com> 11/28/03 01:28PM >>>
Could you try it with instance instead of database?
And actually is TESTORA the name of the computer? Is the database
running on your computer? If so you should use 'localhost'
or '127.0.0.1', if not then try the actual ip of the computer instead
TESTORA, for the host parameter.
       Chris
> hi Chris,
> I made the loggingLevel FINER.On calling
> http://localhost/geoserver/GetCapabilities , i see the oracle part
> in
> the Tomcat windows.I am just placing the Oracle part of the log
which
> i
> hope helps you.
> 354900 [FINER] org.geotools.data.DataSourceFinder - Available
Data
> Sources:
> 354900 [FINER] org.geotools.data.DataSourceFinder - PostGIS
spatial
> database
> 354910 [FINER] org.geotools.data.DataSourceFinder - ESRI(tm)
> Shapefiles (*.shp)
> 354910 [FINE] org.geotools.data.oracle.OracleDataSourceFactory -
> oracle datasource factory constructed
> 354910 [FINER] org.geotools.data.DataSourceFinder - Oracle
Spatial
> Database
> 354910 [FINER] org.geotools.data.oracle.OracleDataSourceFactory -
> canProcess called on {table=test_ora_layers, user=userme,
> passwd=passme,
> host=TESTORA, port=1521, database=TESTORA,
> dbtype=oracle}
> 354910 [FINE] org.vfny.geoserver.responses.WfsException - could
not
> construct a datasource for topp:test_ora_layers with params:
> {table=test_ora_layers, user=userme, passwd=passme, host=TESTORA,
> port=1521, database=TESTORA, dbtype=oracle}
> 354910 [WARNING] org.vfny.geoserver.config.TypeInfo - Could not
get
> DataSource: topp:test_ora_layers during GetCapabilities: could not
> port=1521, database=TESTORA, dbtype=oracle} returning basic
> Capabilities, but GetFeature requests will likely fail.
> 354920 [FINER] org.vfny.geoserver.servlets.Capabilities -
response
> is
> <?xml version="1.0" encoding="UTF-8"?><WFS_Capabilities
> version="1.0.0"
> xmlns="http://www.opengis.net/wfs&quot;
> xmlns:cdf="http://www.opengis.net/cite/data&quot;
> xmlns:topp="http://www.openplans.org/topp&quot;
> xmlns:cgf="http://www.opengis.net/cite/geometry&quot;
> xmlns:ogc="http://www.opengis.net/ogc&quot;
> xsi:schemaLocation="http://www.opengis.net/wfs
> a/capabilities/wfs/1.0.0/WFS-capabilities.xsd">
> <Service>
> <Name>FreeFS</Name>
> <Title>The Open Planning Project Basemap Server</Title>
> <Abstract>This is a test server. It contains some basemap
data
> from New Yor
> k City.</Abstract>
> <Keywords>WFS. CITE. New York</Keywords>
> <OnlineResource>http://www.openplans.org/&lt;/OnlineResource&gt;
> <Fees>NONE</Fees>
> <AccessConstraints>NONE</AccessConstraints>
> </Service>
> <Capability>
> <Request>
> <GetCapabilities>
> <DCPType><HTTP><Get
> onlineResource="http://localhost/geoserver/GetCapabi
> lities?"/></HTTP></DCPType>
> <DCPType><HTTP><Post
> ilities"/></HTTP></DCPType>
> </GetCapabilities>
> <DescribeFeatureType>
<SchemaDescriptionLanguage><XMLSCHEMA/></SchemaDescriptionLanguage>
> <DCPType><HTTP><Get
> onlineResource="http://localhost/geoserver/DescribeF
> eatureType?"/></HTTP></DCPType>
> FeatureType"/></HTTP></DCPType>
> </DescribeFeatureType>
> <GetFeature>
> <ResultFormat><GML2/></ResultFormat>
> <DCPType><HTTP><Get
> onlineResource="http://localhost/geoserver/GetFeatur
> re"/></HTTP></DCPType>
> </GetFeature>
> <Transaction>
> <DCPType><HTTP><Get
> onlineResource="http://localhost/geoserver/Transacti
> on?"/></HTTP></DCPType>
> ion"/></HTTP></DCPType>
> </Transaction>
> <LockFeature>
> <DCPType><HTTP><Get
> onlineResource="http://localhost/geoserver/LockFeatu
> re?"/></HTTP></DCPType>
> ure"/></HTTP></DCPType>
> </LockFeature>
> <GetFeatureWithLock>
> <DCPType><HTTP><Get
> eWithLock?"/></HTTP></DCPType>
> reWithLock"/></HTTP></DCPType>
> </GetFeatureWithLock>
> </Request>
> </Capability>
> <FeatureTypeList>
> <Operations>
> <Query/>
> <Lock/>
> </Operations>
> <FeatureType>
> <Name>topp:road</Name>
> <Title>Random Road Centerlines</Title>
> <Abstract>This is some random road features</Abstract>
> <Keywords>road, New York City, TOPP</Keywords>
> <SRS>http://www.opengis.net/gml/srs/epsg#32118&lt;/SRS&gt;
> <LatLongBoundingBox minx="-74.27000" miny="40.50000"
> maxx="-73.80000" maxy
> ="40.94000"/>
> </FeatureType>
> <FeatureType>
> <Name>topp:rail</Name>
> <Title>NYC Rail Centerlines</Title>
> <Abstract>This is a simple rail coverage from New York
> City</Abstract>
> <Keywords>OWS1, rail, railroad, New York City</Keywords>
> ="40.94000"/>
> </FeatureType>
> <FeatureType>
> <Name>topp:test_ora_layers</Name>
> City</Abstract>
> ="40.94000"/>
> </FeatureType>
> </FeatureTypeList>
> <ogc:Filter_Capabilities>
> <ogc:Spatial_Capabilities>
> <ogc:Spatial_Operators>
> <ogc:Disjoint/>
> <ogc:Equals/>
> <ogc:DWithin/>
> <ogc:Beyond/>
> <ogc:Intersect/>
> <ogc:Touches/>
> <ogc:Crosses/>
> <ogc:Within/>
> <ogc:Contains/>
> <ogc:Overlaps/>
> <ogc:BBOX/>
> </ogc:Spatial_Operators>
> </ogc:Spatial_Capabilities>
> <ogc:Scalar_Capabilities>
> <ogc:Logical_Operators/>
> <ogc:Comparison_Operators>
> <ogc:Simple_Comparisons/>
> <ogc:Between/>
> <ogc:Like/>
> <ogc:NullCheck/>
> </ogc:Comparison_Operators>
> <ogc:Arithmetic_Operators>
> <ogc:Simple_Arithmetic/>
> </ogc:Arithmetic_Operators>
> </ogc:Scalar_Capabilities>
> </ogc:Filter_Capabilities>
> </WFS_Capabilities>
> 354940 [FINER] org.vfny.geoserver.servlets.Capabilities -
response
> encoding is
> UTF-8
> Hope that helps.
> regards
> Gautam
> >>> <cholmes@anonymised.com> 11/28/03 12:37PM >>>
> It looks like you're doing everything correctly. It should
> definitely
> be instance, not database, but if you've tried both then it should
> work. I think the problem may be a classpath issue. If you could
> turn your logging level to finer and start up geoserver, look for a
> line like 'Postgis is an available datasource'. There should also
be
> two more lines: 'Shapefile is an available datasource' and 'oracle
is
> an available datasource' (I'm working off of memory here, might be
> slightly different'. So look for those lines, and if the oracle
one
> is not there then that's probably the problem. If it is I can
> probably fix it for you relatively easily (you just have to get the
> servlet container recognizing the right meta-inf/service/Data...
> line,
> that tells which factories are available). If not then we'll have
to
> investigate further. Let me know and we can better diagnose the
> problem. And thanks for the nice detailed message.
> Chris
> > hi all,
> > I am trying to make Geoserver to use oracle-spatial.When i use
> the
> > url:
http://localhost/geoserver/GetFeature?typename=topp:test_ora_layers
> > i get the following on my browser:
> > <ServiceExceptionReport version="1.2.0"
> > http://localhost/geoserver/data/capabilities/wfs/1.0.0/OGC-
> exception.xsd">
> > <ServiceException>Please contact the admin, the configuration
> for
> > topp:test_ora_layers has
> > an error. No datasource could be constructed with the params:
> > user=userme, passwd=passme, host=TESTORA, port=1521,
> > database=TESTORA, dbtype=oracle} from the
> > info.xml file.</ServiceException></ServiceExceptionReport>
> > I did notice the following message on the tomcat screen:
> > 127853 [WARNING] org.vfny.geoserver.config.TypeInfo - Could not
> get
> > DataSource:
construct
> a
> > datasource
> > for topp:test_ora_layers with params: {table=test_ora_layers,
> > user=userme,
> > passwd=passme, host=TESTORA, port=1521, database=TESTORA,
> > basic Capabilities, but GetFeature requests will likely fail.
> > My system settings are:
> > OS-Win2000
> > Database - oracle Spatial-1.1.7
> > WebServer - IIS-5.0
> > Tomcat-4.1.27
> > Geoserver ver - 1.0
> > As per the docs,i built Geoserver.war and also managed to
> installed
> > it
> > under Tomcat.
> > Calling the url http:\\localhost\geoserver\getcapabilities..i do
> get
> > the xml doc returned
> > to me in the browser.
> > As per the doc,to make it work with Oracle..i followed all the
> > steps
> > as mentioned there.
> > I got the classes12.zip and sdoapi.zip from oracle and renamed
> them
> > to
> > classes12.jar and sdoapi.jar and placed them into the
> > c:\tomcat\webapps\geoserver\web-inf\lib dir.The oracle table has
> the
> > following table description:
> > sql>desc test_ora_layers
> > Name Null? Type
> > LAYER_ID NUMBER
> > SHAPE
> > MDSYS.SDO_GEOMETRY
> > I have the directory under \data\featureTypes\test_ora_layers,as
> > mentioned in the doc.
> > The datasourceparams tag inside the info.xml looks like these:
> > <DatasourceParams>
> > <host>TESTORA</host>
> > <port>1521</port>
> > <instance>TESTORA</instance>
> > <user>userme</user>
> > <passwd>passme</passwd>
> > <table>test_ora_layers</table>
> > <dbtype>oracle</dbtype>
> > </DatasourceParams>
> > The Schema.xml looks like these:
> > <xs:complexContent>
> > <xs:sequence>
> minOccurs="0"
> > maxOccurs="1">
> > <xs:simpleType>
> > </xs:restriction>
> > </xs:simpleType>
> > </xs:element>
> > </xs:sequence>
> > </xs:extension>
> > </xs:complexType>
> > Also in the doc,it is mentioned that in case of oracle,the
> > DataSourceParams tag has a child node called <instance> and not
> > <database>.Looking at the FeatureType.java,were these
> > tags are read in the function getDataParams(..), i saw that
these
> > function looks for tag called <database>,so i even changed it
from
> > "instance" to "database" tag but that didnot help it either.
> > Any help or suggestion would be highly appreciated.
> > regards,
> > Gautam
> > This SF.net email is sponsored by: SF.net Giveback Program.
> > Does SourceForge.net help you be more productive? Does it
> > help you create better code? SHARE THE LOVE, and help us help
> > YOU! Click Here: http://sourceforge.net/donate/
> > _______________________________________________
> > Geoserver-devel mailing list
> > Geoserver-devel@lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geoserver-devel
> This mail sent through IMP: http://horde.org/imp/
Gautam,
The problem you have now ("SQL Error occured when generating unique
key") is very familiar to me (and Chris, indeed, you have seen it
before...). I'm not quite sure anymore what helped me out then (so
anyone, please correct me if I'm wrong), but you could check whether you
have a primary key defined on your table. You can check in the table
user_constraints whether there is an entry for a primary key and whether
it is decalred properly. If there is no primary key defined, you should
create one. Hope this helps. If not, maybe I can help more after the
weekend, since I cannot see my notes on this issue right now.
Thijs Brentjens
-----Original Message-----
[mailto:geoserver-devel-admin@lists.sourceforge.net] On Behalf Of
Sent: vrijdag 28 november 2003 21:15
To: Gautam Ganguly
Cc: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] Oracle Spatial-NO connection error
          Chris
Chris,
  I think the connection issue is solved as soon as i changed the tag
of
message:
request is
typeDir
read types at
C:\Tomcat\w
nodes:
29
property
with 1.2.3.4
property
with 1521
property
with TESTORA
property
with userme
property
with passme
property
property
with oracle
the
{table=fw_layers_3
port=1521
, dbtype=oracle}
Sources:
database
Shapefiles
(*.shp)
oracle
datasour
Database
canProcess cal
passwd=passme,
create
ds
called in oracle
canProcess cal
passwd=passme,
connections,
creating a new one.
81567 [FINE]
[test_ora_layers]:
exception
   version="1.2.0"
   </ServiceException>
very much for that.
    <xs:complexContent>
        <xs:sequence>
maxOccurs="1">
            <xs:simpleType>
              </xs:restriction>
            </xs:simpleType>
          </xs:element>
        </xs:sequence>
</xs:extension>
</xs:complexType>
thanks again.
regards,
Gautam
       Chris
> hi Chris,
> in the Tomcat windows.I am just placing the Oracle part of the log
which
> i
> hope helps you.
Data
> Sources:
spatial
> database
> Shapefiles (*.shp) 354910 [FINE]
> org.geotools.data.oracle.OracleDataSourceFactory - oracle datasource
> factory constructed 354910 [FINER]
Spatial
> Database
> dbtype=oracle}
not
> port=1521, database=TESTORA, dbtype=oracle} 354910 [WARNING]
get
> Capabilities, but GetFeature requests will likely fail. 354920
response
> is
> version="1.0.0"
> <Service>
> <Name>FreeFS</Name>
data
> from New Yor
> k City.</Abstract>
> <Fees>NONE</Fees>
> </Service>
> <Capability>
> <Request>
> <GetCapabilities>
> <DCPType><HTTP><Get
> </GetCapabilities>
> <DCPType><HTTP><Get
> <GetFeature>
> <DCPType><HTTP><Get
> </GetFeature>
> <Transaction>
> <DCPType><HTTP><Get
> </Transaction>
> <LockFeature>
> <DCPType><HTTP><Get
> </LockFeature>
> <DCPType><HTTP><Get
> </Request>
> </Capability>
> <FeatureTypeList>
> <Operations>
> <Query/>
> <Lock/>
> </Operations>
> <FeatureType>
> maxx="-73.80000" maxy ="40.94000"/>
> </FeatureType>
> <FeatureType>
> City</Abstract>
> ="40.94000"/>
> </FeatureType>
> <FeatureType>
> City</Abstract>
> ="40.94000"/>
> </FeatureType>
> </FeatureTypeList>
> <ogc:Disjoint/>
> <ogc:Equals/>
> <ogc:DWithin/>
> <ogc:Beyond/>
> <ogc:Intersect/>
> <ogc:Touches/>
> <ogc:Crosses/>
> <ogc:Within/>
> <ogc:Contains/>
> <ogc:Overlaps/>
> <ogc:BBOX/>
> <ogc:Between/>
> <ogc:Like/>
> <ogc:NullCheck/>
> </WFS_Capabilities>
response
> encoding is
> UTF-8
> Hope that helps.
> regards
> Gautam
> definitely
be
is
one
> line,
to
> Chris
> > hi all,
> the
> > url:
> exception.xsd">
> for
> get
> > DataSource:
construct
> a
> > datasource
> > user=userme,
> > OS-Win2000
> > WebServer - IIS-5.0
> > Tomcat-4.1.27
> > Geoserver ver - 1.0
> installed
> > it
> > under Tomcat.
> get
> > steps as mentioned there.
> them
> > to
> the
> > Name Null? Type
> > LAYER_ID NUMBER
> > SHAPE
> > MDSYS.SDO_GEOMETRY
> > <DatasourceParams>
> > <port>1521</port>
> > <user>userme</user>
> > </DatasourceParams>
> > <xs:complexContent>
> > <xs:extension base="gml:AbstractFeatureType"> <xs:sequence>
> minOccurs="0"
> > maxOccurs="1">
> > <xs:simpleType>
> > </xs:restriction>
> > </xs:simpleType>
> > </xs:element>
> > </xs:sequence>
> > </xs:extension>
> > </xs:complexType>
> > <database>.Looking at the FeatureType.java,were these tags are
these
from
> > regards,
> > Gautam
> > This SF.net email is sponsored by: SF.net Giveback Program. Does
> > SourceForge.net help you be more productive? Does it help you
> > create better code? SHARE THE LOVE, and help us help YOU! Click
> > Geoserver-devel mailing list Geoserver-devel@lists.sourceforge.net
SourceForge.net help you be more productive? Does it help you create
better code? SHARE THE LOVE, and help us help YOU! Click Here:
Hi Gautam,
This can happen if the table does not have single primary key defined. Can you make sure it does?
Sean
cholmes@anonymised.com wrote:
Yes, looks like you solved the connection issue. For your next issue, no, it's not because the schema.xml file is wrong, that would not cause such an error. I'm going to have to defer to Sean on this one, as he's the oracle expert. He will likely reply fairly soon, I think we've seen this before, but I don't remember the solution. It's probably something with how your oracle tables are set up.
         Chris
At 23:11 28/11/2003 +0100, Thijs Brentjens wrote:
Gautam,
This error is definitely cured by adding a primary key - The problem seems to be that oracle data-source assuming it can use OBJECTID if there is no PK, my oracle expert advised me that it should be OBJECT_ID. However I have not tested this since I'd already added PKs to my tables.
Ian
Ian Turton, Director, Centre for Computational Geography, University of Leeds, Leeds, LS2 9JT
http://www.geog.leeds.ac.uk/people/i.turton http://www.ccg.leeds.ac.uk http://www.geotools.org
+44 (0) 113 343 3392 fax: +44 (0) 113 343 3308
