Sean,
After changing the LoggingLevel to finest,these is what i could grab
from the DOS window..its not the full logging but the end part of
it..which i hope helps you.
Extension[org.apache.commons.logging, implementationVendor=Apache
Software F
oundation, implementationVersion=1.0.3, specificationVendor=Apache
Software Foun
dation, specificationVersion=1.0]
Extension[org.apache.tools.ant, implementationVendor=Apache
Software Foundat
ion, implementationVersion=1.5.3, specificationVendor=Apache Software
Foundation
, specificationVersion=1.5.3]
delegate: true
repositories:
file:C:\Tomcat\common\classes\
file:C:\Tomcat\common\lib\jasper-runtime.jar
file:C:\Tomcat\common\lib\jasper-compiler.jar
file:C:\Tomcat\common\lib\commons-collections.jar
file:C:\Tomcat\common\lib\naming-resources.jar
file:C:\Tomcat\common\lib\naming-common.jar
file:C:\Tomcat\common\lib\commons-logging-api.jar
file:C:\Tomcat\common\lib\ant.jar
file:C:\Tomcat\common\lib\servlet.jar
file:C:\Tomcat\common\lib\naming-factory.jar
file:C:\Tomcat\common\lib\tools.jar
required:
----------> Parent Classloader:
sun.misc.Launcher$AppClassLoader@anonymised.com
61309 [FINEST] org.geotools.factory.FactoryFinder -
findFactory(org.geotools.fe
ature.FeatureTypeFactory,org.geotools.feature.DefaultFeatureTypeFactory,WebappCl
assLoader
available:
delegate: false
repositories:
/WEB-INF/classes/
required:
StandardClassLoader
available:
delegate: true
repositories:
file:C:\Tomcat\shared\classes\
required:
StandardClassLoader
available:
Extension[org.apache.commons.collections,
implementationVendor=Apache Softwa
re Foundation, implementationVersion=2.1, specificationVendor=Apache
Software Fo
undation, specificationVersion=2.1]
Software F
Software Foun
Software Foundat
Foundation
delegate: true
repositories:
required:
61309 [FINEST] org.geotools.factory.FactoryFinder - ClassLoader :
WebappClassLo
ader
available:
delegate: false
repositories:
/WEB-INF/classes/
required:
StandardClassLoader
available:
delegate: true
repositories:
required:
StandardClassLoader
available:
Software Fo
Software F
Software Foun
Software Foundat
Foundation
delegate: true
repositories:
required:
61309 [FINEST] org.geotools.factory.FactoryFinder - Searching system
properties
61309 [FINEST] org.geotools.factory.FactoryFinder - Key
'org.geotools.feature.F
eatureTypeFactory' not found
61309 [FINEST] org.geotools.factory.FactoryFinder - Searching for
service: META
-INF/services/org.geotools.feature.FeatureTypeFactory
61309 [FINEST] org.geotools.factory.FactoryFinder - Reading Factory ,
has strea
m : false
61309 [FINEST] org.geotools.factory.FactoryFinder - Service
'META-INF/services/
org.geotools.feature.FeatureTypeFactory' not found
61309 [FINEST] org.geotools.factory.FactoryFinder - Resorting to
default
61309 [FINEST] org.geotools.factory.FactoryFinder - Creating instance
from 'org
.geotools.feature.DefaultFeatureTypeFactory'
61319 [FINEST] org.geotools.factory.FactoryFinder - Finding
ClassLoader
61329 [FINEST] org.geotools.factory.FactoryFinder - Using context
ClassLoader W
ebappClassLoader
available:
delegate: false
repositories:
/WEB-INF/classes/
required:
StandardClassLoader
available:
delegate: true
repositories:
required:
StandardClassLoader
available:
Software Fo
Software F
Software Foun
Software Foundat
Foundation
delegate: true
repositories:
required:
assLoader
available:
delegate: false
repositories:
/WEB-INF/classes/
required:
StandardClassLoader
available:
delegate: true
repositories:
required:
StandardClassLoader
available:
Software Fo
Software F
Software Foun
Software Foundat
Foundation
delegate: true
repositories:
required:
61329 [FINEST] org.geotools.factory.FactoryFinder - ClassLoader :
WebappClassLo
ader
available:
delegate: false
repositories:
/WEB-INF/classes/
required:
StandardClassLoader
available:
delegate: true
repositories:
required:
StandardClassLoader
available:
Software Fo
Software F
Software Foun
Software Foundat
Foundation
delegate: true
repositories:
required:
61329 [FINEST] org.geotools.factory.FactoryFinder - Searching system
properties
61329 [FINEST] org.geotools.factory.FactoryFinder - Key
61329 [FINEST] org.geotools.factory.FactoryFinder - Searching for
service: META
61329 [FINEST] org.geotools.factory.FactoryFinder - Reading Factory ,
has strea
m : false
61329 [FINEST] org.geotools.factory.FactoryFinder - Service
'META-INF/services/
61329 [FINEST] org.geotools.factory.FactoryFinder - Resorting to
default
61339 [FINEST] org.geotools.factory.FactoryFinder - Creating instance
from 'org
61369 [FINE]
org.geotools.data.jdbc.ConnectionPool$ConnectionListManager - Conn
ection closed - adding to available connections.
61369 [FINEST] org.vfny.geoserver.config.TypeInfo - returning name
test_ora_lay
ers
61369 [FINE] org.vfny.geoserver.responses.WfsException - >
[test_ora_layers]:
While getting connection to datasource:
org.geotools.data.DataSourceException:
SQL Error occured when generating unique key
61369 [FINE] org.vfny.geoserver.responses.WfsException - return wfs
exception i
s <?xml version="1.0" ?>
<ServiceExceptionReport
version="1.2.0"
xmlns="http://www.opengis.net/ogc"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/ogc
http://localhost/geoserver/dat
a/capabilities/wfs/1.0.0/OGC-exception.xsd">
<ServiceException locator="test_ora_layers">
ion: SQL Error occured when generating unique key
</ServiceException>
</ServiceExceptionReport>
regards
Gautam
Sean Geoghegan <sean@anonymised.com> 11/29/03 03:01PM >>>
Chris,
Do you know why the nested exception is not showing up? At this point
I
really need to see the details of the nested SQLException to diagnose
the problem.
Gautam, can you maybe look in Tomcats stderr.log file to see if there
is
any more info and set the log level to FINEST aswell.
Thanks
Sean
Gautam Ganguly wrote:
hi Sean,
Sorry for replying to your mail ,a bit late.No the table did not
have
a primary key.But i added a primary key field called FID of type
number, after having read Thijs Brentjens's mail. These is the new
structure of the table after doing so:
SQL> desc test_ora_layers
Name Null? Type
FID NOT NULL NUMBER(10)
LAYER_ID NUMBER(10)
SHAPE
MDSYS.SDO_GEOMETRY
But it didnot help much when i called :
http://localhost/geoserver/GetFeature?typename=topp:test_ora_layersI see the same error message on my browser:
- <ServiceExceptionReport version="1.2.0"
http://localhost/geoserver/data/capabilities/wfs/1.0.0/OGC-exception.xsd">
<ServiceException locator="test_ora_layers">While getting
connection
to datasource: org.geotools.data.DataSourceException:
SQL Error occured when generating unique key</ServiceException>
I have the LoggingLevel still at finer,so the log on the tomcat
screen
shows the following:
193201 [FINE] org.geotools.data.oracle.OracleDataSourceFactory -
oracle
datasource factory constructed
193201 [FINER] org.geotools.data.DataSourceFinder - Oracle Spatial
Database
193201 [FINER] org.geotools.data.oracle.OracleDataSourceFactory -
canProcess
called on {table=test_ora_layers, user=userme, instance=TESTORA,
passwd=passme,
host=1.2.3.4, port=1521, dbtype=oracle}
create ds
called in oracle
canProcess
passwd=passme,
193311 [FINE] org.geotools.data.jdbc.ConnectionPool - No available
connections,
creating a new one.
194603 [FINE]
Connection closed - adding to available connections.
194603 [FINE] org.vfny.geoserver.responses.WfsException - >
[test_ora_layers]:
194613 [FINE] org.vfny.geoserver.responses.WfsException - return wfs
exception
is <?xml version="1.0" ?>
version="1.2.0"
</ServiceException>
With the new changes to the table , my schema.xml looks like these:<xs:complexType name="test_ora_layers_Type">
<xs:complexContent>
<xs:extension base="gml:AbstractFeatureType">
<xs:sequence>
<xs:element name="fid" nillable="false" minOccurs="1"
maxOccurs="1">
<xs:simpleType>
<xs:restriction base="xs:integer">
<xs:totalDigits value="10"/>
</xs:restriction>
</xs:simpleType>
</xs:element>
<xs:element name="layer_id" nillable="true" minOccurs="0"
maxOccurs="1">
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:element>
<xs:element name="shape" type="gml:PolygonPropertyType"
nillable="false" minOccurs="1" maxOccurs="1"/>
</xs:sequence>
</xs:extension>
</xs:complexContent>
</xs:complexType>
hope that helps.regards,
gautam
