I was just browsing through the OracleDialect.java (gs 2.3.5, gt 9.5),
debugging a problem, when i came across this function:
@Override
public Class<?> getMapping(ResultSet columnMetaData, Connection cx)
throws SQLException {
final int TABLE_NAME = 3;
final int COLUMN_NAME = 4;
final int TYPE_NAME = 6;
String typeName = columnMetaData.getString(TYPE_NAME);
if (typeName.equals("SDO_GEOMETRY")) {
String tableName = columnMetaData.getString(TABLE_NAME);
String columnName = columnMetaData.getString(COLUMN_NAME);
String schema = dataStore.getDatabaseSchema();Class geometryClass = lookupGeometryOnMetadataTable(cx,
tableName, columnName, schema);
if (geometryClass == null) {
lookupGeometryClassOnUserIndex(cx, tableName, columnName,
schema);
geometryClass = lookupGeometryClassOnAllIndex(cx,
geometryClass = Geometry.class;
}return geometryClass;
} else {
// if we know, return non null value, otherwise returning
// null will force the datatore to figure it out using
// jdbc metadata
return TYPES_TO_CLASSES.get(typeName);
Is is just me, or should this line:
schema);
actually say:
geometryClass = lookupGeometryClassOnUserIndex(cx,
View this message in context: http://osgeo-org.1560.x6.nabble.com/OracleDialect-tp5073930.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
