On Sun, 2010-10-03 at 00:00 +0200, Andrea Aime wrote:
On Sat, Oct 2, 2010 at 10:18 PM, Gabriel Roldán <groldan@anonymised.com> wrote:
> Hey,
> tried a tentative upgrade for the org.restlet dependencies version, from
> 1.0.8 to the latest stable 1.1.10, because I need support for setting
> the HTTP header "content-disposition" and it was added only at version
> 1.1. Also note 1.0.x is more than three years old?
> Any objection in upgrading to restlet api 1.1.10? (would need to be both
> for trunk and 2.0.x.
Is it binary compatible? I thought they changed the API somehow
between versions.
As a line of principle I have nothing against upgrading trunk, but
2.0.x... it has to be
a rock solid upgrade to go there. I'm not clairvoyant but I guess next
2.0.x release,
if/when we make it, will be the last, so it would better to be stable
Just my two cents, hopefully others will bring more info to the table
I agree. As far as I can tell it's binary compatible and didn't see a
single deprecation warning when upgrading. Only thing is some tests
break what's solved with the patch copied bellow.
They're on 2.0-beta now so that's probably the one that will carry over
some incompatibility. But I'll be glad to test more thoroughly 1.1.10
before committing. By the other hand, to stay on the safest side for
2.0.x I would rather push for a 2.1-beta2 release sometime soon so
geonode could move on.
index e65c684..6bb6aa8 100644
--- a/rest/src/test/java/org/geoserver/rest/RestletTestSupport.java
+++ b/rest/src/test/java/org/geoserver/rest/RestletTestSupport.java
@@ -21,6 +21,7 @@ import net.sf.json.JSONSerializer;
import org.custommonkey.xmlunit.XMLUnit;
import org.custommonkey.xmlunit.XpathEngine;
+import org.restlet.Application;
import org.restlet.data.MediaType;
import org.restlet.data.Method;
import org.restlet.data.Request;
@@ -35,7 +36,7 @@ public abstract class RestletTestSupport extends
TestCase {
@Override
protected void setUp() throws Exception {
super.setUp();
+ Application.setCurrent(new Application());
xp = XMLUnit.newXpathEngine();
Ing. Andrea Aime
Senior Software Engineer
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Gabriel Roldan
Expert service straight from the developers
