Hi everyone, I have a problem.
I'm trying to modify a MapBuilder in GeoServer, but a problem occured and I don't know what. Can anyone help me? Thanks a lot.
The log of GeoServer is:
62750 [btpool0-3] INFO org.springframework.web.servlet.handler.SimpleUrlHandlerMapping - Default mapping to handler [org.geoserver.request.Dispatcher@
914a0a]
62750 [btpool0-3] INFO org.springframework.web.servlet.DispatcherServlet - Using context class [org.springframework.web.context.support.XmlWebApplicat
ionContext] for servlet 'dispatcher'
62750 [btpool0-3] INFO org.springframework.web.servlet.DispatcherServlet - Unable to locate MultipartResolver with name 'multipartResolver': no multip
art request handling provided
62766 [btpool0-3] INFO org.springframework.web.servlet.DispatcherServlet - Unable to locate LocaleResolver with name 'localeResolver': using default [
org.springframework.web.servlet.i18n.AcceptHeaderLocaleResolver@anonymised.com]
62766 [btpool0-3] INFO org.springframework.web.servlet.DispatcherServlet - Unable to locate ThemeResolver with name 'themeResolver': using default [or
g.springframework.web.servlet.theme.FixedThemeResolver@anonymised.com]
62766 [btpool0-3] INFO org.springframework.web.servlet.DispatcherServlet - No HandlerAdapters found in servlet 'dispatcher': using default
62781 [btpool0-3] INFO org.springframework.web.servlet.DispatcherServlet - No ViewResolvers found in servlet 'dispatcher': using default
62781 [btpool0-3] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'dispatcher': initialization completed in 109 ms
62781 [btpool0-3] INFO org.springframework.web.servlet.DispatcherServlet - Servlet 'dispatcher' configured successfully
59296 [INFO] org.vfny.geoserver.servlets.AbstractService - handling request: org.vfny.geoserver.wms.requests.GetMapRequest@anonymised.com
59328 [INFO] org.vfny.geoserver.servlets.AbstractService - handling request: org.vfny.geoserver.wms.requests.GetMapRequest@anonymised.com
59687 [INFO] org.vfny.geoserver.servlets.AbstractService - Service handled
59703 [INFO] org.vfny.geoserver.servlets.AbstractService - handling request: org.vfny.geoserver.wms.requests.GetMapRequest@anonymised.com
59734 [INFO] org.vfny.geoserver.servlets.AbstractService - Service handled
59750 [INFO] org.vfny.geoserver.servlets.AbstractService - handling request: org.vfny.geoserver.wms.requests.GetMapRequest@anonymised.com
59890 [INFO] org.vfny.geoserver.servlets.AbstractService - Service handled
60343 [GRAVE] org.vfny.geoserver.servlets.AbstractService - Error writing out null
org.mortbay.jetty.EofException
at org.mortbay.jetty.HttpGenerator.flushBuffers(HttpGenerator.java:856)
at org.mortbay.jetty.HttpGenerator$Output.flush(HttpGenerator.java:1069)
at org.mortbay.jetty.HttpConnection$Output.flush(HttpConnection.java:764)
at java.io.BufferedOutputStream.flush(BufferedOutputStream.java:124)
at org.vfny.geoserver.util.PartialBufferedOutputStream.forceFlush(PartialBufferedOutputStream.java:206)
at org.vfny.geoserver.servlets.PartialBufferStrategy.flush(PartialBufferStrategy.java:67)
at org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:596)
at org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:333)
at org.geoserver.request.Dispatcher.dispatch(Dispatcher.java:183)
at org.geoserver.request.Dispatcher.handleRequestInternal(Dispatcher.java:58)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:445)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1050)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:122)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1041)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:354)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:226)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:627)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:149)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:123)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:141)
at org.mortbay.jetty.Server.handle(Server.java:269)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:430)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:687)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:492)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:199)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:339)
at org.mortbay.jetty.nio.HttpChannelEndPoint.run(HttpChannelEndPoint.java:270)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:475)
Caused by: java.io.IOException: Se ha forzado la interrupci¾n de una conexi¾n existente por el host remoto
at sun.nio.ch.SocketDispatcher.writev0(Native Method)
at sun.nio.ch.SocketDispatcher.writev(SocketDispatcher.java:37)
at sun.nio.ch.IOUtil.write(IOUtil.java:164)
at sun.nio.ch.SocketChannelImpl.write0(SocketChannelImpl.java:331)
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:354)
at java.nio.channels.SocketChannel.write(SocketChannel.java:360)
at org.mortbay.io.nio.ChannelEndPoint.flush(ChannelEndPoint.java:238)
at org.mortbay.jetty.nio.HttpChannelEndPoint.flush(HttpChannelEndPoint.java:140)
at org.mortbay.jetty.HttpGenerator.flushBuffers(HttpGenerator.java:778)
... 35 more
60343 [ADVERTENCIA] org.vfny.geoserver.servlets.PartialBufferStrategy - OutputStream could not be aborted in time. An error has occurred and could no
t be sent to the user.
60343 [INFO] org.vfny.geoserver.servlets.AbstractService - Had an undefined error: null
63984 [btpool0-3] ERROR org.springframework.web.servlet.DispatcherServlet - Could not complete request
java.lang.IllegalStateException: STREAM 60375 [INFO] org.vfny.geoserver.servlets.AbstractService - Service handled
at org.mortbay.jetty.Response.getWriter(Response.java:502)
at org.vfny.geoserver.servlets.AbstractService.send(AbstractService.java:844)
at org.vfny.geoserver.servlets.AbstractService.sendError(AbstractService.java:900)
at org.vfny.geoserver.servlets.AbstractService.sendError(AbstractService.java:883)
at org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:607)
64062 [btpool0-3] ERROR org.mortbay.log - /geoserver/wms:
_________________________________________________________________
Descubre la descarga digital con MSN Music. Más de un millón de canciones. http://music.msn.es/
