[Geoserver-devel] Our build test memory filled by finalizers
today I was checking out the build for a new PDF generation test I added,
and observed very slow build and eventually a “OOM, GC overhead exceeeded”.
I’ve investigated and found out that:
  • We were already on the brink of failure
  • The new test, first one to verify the PDF output, added some 30+ MB of heap usage caused by some iText internal font cache, made it overflow
    I’ve then looked at a heap dump of the surefire jvm and found this (mind, this is a dump of the surefire without my changes, I wanted to make sure
the new test was not altering things significantly, and indeed confirmed it was merely adding the last drop making the bucket overflow):
Inline image 1
Now, the surefire JVM is allowed only 512MB of heap, the Class are the top are likely accounting the new metaspace.
So the heap is mostly filled by that ton of Finalizer, which variably refer to many of the objects you see below.
Why are we getting there? Because we are creating a very high number of objects that sport a finalize() method, sampling though the
object explorer I’ve found large numbers of FileInputStream/FileOutputStream/ZipFileInflaterInputStream/Deflater/CloseableIteratorAdapter/MapContent and many others.
That is coupled with a JVM own limitation, the finalizer thread is only one and is low priority… when the memory gets filled with finalizers
the GC is not able to push the finalizer to work more, has less and less space to work with, and eventually the JVM gives up
by throwing the dreaded “java.lang.OutOfMemoryError: GC overhead limit exceeded”.
So… what to do about it? Eh… One thing to try is to raise the finalizer thread priority… too bad that does not work on Linux unless the user
making the switch is the root user himself.
Other options:
  • Reduce the usage of objects with finalizers
  • Give tests more memory (now they are at 512MB)
  • Run finalization explicitly using System.runFinalization() at the end of each test class (as an @AfterClass of sorts)
The first one is a lot of work with no guaranteed results due to the many JVM classes currently held by finalizers (but it would still be
a good thing to think twice before adding a finalizer onto an object that gets used a lot).
Tried the second one, giving it 768MB of heap, works.
[INFO]
[INFO] Main Module … SUCCESS [01:57 min]
[INFO] Web Feature Service Module … SUCCESS [01:17 min]
[INFO] Web Map Service Module … SUCCESS [01:43 min]
And then the third option, only 512MB of heap but manually forcing the run of finalization at end… got the GC overhead exceeded
anyways (a bit surprised about it, but oh well…). Also works, but build times suffer greatly:
[INFO] Main Module … SUCCESS [01:56 min]
[INFO] Web Feature Service Module … SUCCESS [01:14 min]
[INFO] Web Map Service Module … SUCCESS [02:33 min]
So… I’d say it’s best to increase the heap size. Unless anyone else has alternative suggestions?
Sure, I could commit the work on PDF without tests (the horror…), but it’s just a matter of time
before we get back to square one…
Pull request for the PDF change and memory increase here:
https://github.com/geoserver/geoserver/pull/2094
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Ah, by the way, probably not relevant to this discussion, but
looking at some performance charts, it seems that we are leaking threads:
Inline image 1
I can count 90 FileSystemWatcher, so I guess that during a build test run we are setting up and not properly cleaning up a lot of them.
We should probably open a ticket about that right?
(attachments)
On Tue, Feb 7, 2017 at 3:19 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Inline image 1
Other options:
[INFO]
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Ah hem,
I had another look and think I’ve found a smoking gun. See here:
Inline image 1
So the MapContent has a finalize method, and contains layers, which refer to resources, which refer to the catalog,
which ends up referring to the whole application context.
The blasted thing is literally keeping up a “GeoServer worth of memory” pending for finalization.
And there are
We could just remove that finalize method… I’ve also found this article talking about alternative approaches, like
using weak references instead, which could be interesting, but requires some study:
http://www.oracle.com/technetwork/articles/java/finalization-137655.html
Wondering, anyone interesting in pursuing this?
(attachments)
Inline image 1
Other options:
[INFO]
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
while removing that gives some relief, I’ve also found something just blocking the finalizer for extended amounts of
time:
“Finalizer” #3 daemon prio=8 os_prio=0 tid=0x00007f1d701d3800 nid=0x76b1 runnable [0x00007f1d4a5e4000]
java.lang.Thread.State: RUNNABLE
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
  • locked <0x00000000f57d8a48> (a java.net.SocksSocketImpl)
    at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
    at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
    at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
    at java.net.Socket.connect(Socket.java:589)
    at java.net.Socket.connect(Socket.java:538)
    at java.net.Socket.(Socket.java:434)
    at java.net.Socket.(Socket.java:244)
    at javax.media.jai.remote.SerializableRenderedImage.connectToServer(SerializableRenderedImage.java:1169)
    at javax.media.jai.remote.SerializableRenderedImage.closeClient(SerializableRenderedImage.java:1105)
    at javax.media.jai.remote.SerializableRenderedImage.dispose(SerializableRenderedImage.java:1314)
    at javax.media.jai.remote.SerializableRenderedImage.finalize(SerializableRenderedImage.java:1259)
    at java.lang.System$2.invokeFinalize(System.java:1270)
    at java.lang.ref.Finalizer.runFinalizer(Finalizer.java:98)
    at java.lang.ref.Finalizer.access$100(Finalizer.java:34)
    at java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:210)
This is a class used to store on disk a SampleModel and ColorModel in the image mosaic, which for
some forsaken reason decides to open a socket and let it time out during finalization… we’ll have
to find another way to store the same information without using SerializableRenderedImage
(attachments)
On Wed, Feb 8, 2017 at 10:08 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ah hem,
Inline image 1
And there are
Inline image 1
Other options:
[INFO]
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Ok,
so I’ve made a fix removing the SerializableRendererImage down in GeoTools (backwards compatibile with
silent upgrade) and then also made the code release the map content early.
Seems to be building fine now.
In case you want to have a look, it’s the second commit in this pull request:
https://github.com/geoserver/geoserver/pull/2094/commits
(attachments)
On Wed, Feb 8, 2017 at 11:17 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
time:
Ah hem,
Inline image 1
And there are
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Feb 7, 2017 at 3:19 PM, Andrea Aime <andrea.aime@anonymised.com68…> wrote:
Inline image 1
Other options:
[INFO]
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
I am interested in pursuing this, and expect that it is my fault for trying to make MapContext easier to use for GeoTools developers (and calling them out when they leak resources by not calling dispose() ).
We already do have a dispose() method - one of the suggestions provided by your link. Happy to help untangle up to and including not making MapContext finalized.
(attachments)
On 8 February 2017 at 01:08, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ah hem,
Inline image 1
And there are
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Jody Garnett
Inline image 1
Other options:
[INFO]
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Reviewing now; what other help do you need?
(attachments)
On 8 February 2017 at 09:51, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ok,
Jody Garnett
time:
Ing. Andrea Aime
@geowolf
Technical Lead
Ah hem,
Inline image 1
And there are
Ing. Andrea Aime
@geowolf
Technical Lead
Inline image 1
Other options:
[INFO]
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Jody,
a review will do I believe, checking a memory dump after those two fixes the finalization queue is only holding up
something like 1.5MB worth of memory, so I’d say this problem is actually gone.
The other thing that is a bit worrysome is the file watcher threads not being closed, but that does not seem to be
affecting the build all that much. I’ve created a separate ticket for it:
https://osgeo-org.atlassian.net/browse/GEOS-7983
(attachments)
On Wed, Feb 8, 2017 at 7:03 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Ok,
Geoserver-devel@anonymised.comrge.net
time:
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Feb 8, 2017 at 10:08 AM, Andrea Aime <andrea.aime@anonymised.com1268…> wrote:
Ah hem,
Inline image 1
And there are
Ing. Andrea Aime
@geowolf
Technical Lead
Inline image 1
Other options:
[INFO]
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Great work, Andrea. I have seen this finalizer crapflood when running gt-netcdf unit tests in Eclipse, and I could never figure out what was causing it!
Kind regards,
Ben.
On 08/02/17 23:17, Andrea Aime wrote:
while removing that gives some relief, I've also found something just
time:
"Finalizer" #3 daemon prio=8 os_prio=0 tid=0x00007f1d701d3800 nid=0x76b1
at
- locked <0x00000000f57d8a48> (a java.net.SocksSocketImpl)
at
at
at java.net.Socket.<init>(Socket.java:434)
at java.net.Socket.<init>(Socket.java:244)
at
at
at
at
finalization... we'll have
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
