On Wednesday 02 April 2008 05:22:26 pm Andrea Aime wrote:
Gabriel Roldán ha scritto:
> On Wednesday 02 April 2008 04:54:47 pm Justin Deoliveira wrote:
>> Generally in cases like these, i will insert a "leniency hack" if we
>> used to support the behavior, because technically its a regression.
> But you mean a "configurable" hack? like to enable it from the ui or
> something? or just a silent hack?
I would like it as default behaviour, and become picky when the cite
hacks are turned on.
>> I am also usually for being lenient with xml requests in general. But if
>> there is strong opposition to this I could go either way.
> Not a strong opposition but a bad smell. Its a regression because we used
> to be tolerant with the validity of the xml requests we received, or
> because we used to be dumber at parsing?
> It smells bad because that request is a valid xml, its just saying the
> namespace for the "states" type is the request default one, so going
> through the request and assuming that someone using the request default
> namespace for the typename is wrong is a double edged knife...
That's what we used to do, so we're breaking existing clients that were
coded against geoserver < 1.6.x (like udig). This is a regression in my
book.
This is a bug in previous versions of geoserver in mine
Ok, lets do that as a hack for when cite compliance is not set so?
Also, how is it that the default namespace of xml elements gets
inherited by the value of an element?
Because the TypeName element is of QName type:
<xsd:complexType name="DescribeFeatureTypeType">
<xsd:complexContent>
<xsd:extension base="wfs:BaseRequestType">
<xsd:sequence>
<xsd:element name="TypeName" type="xsd:QName"
minOccurs="0" maxOccurs="unbounded">
Is this standard behaviour?
yup, quoting from <http://www.w3.org/TR/xmlschema-2/#QName>:
"The mapping between literals in the ·lexical space· and values in the ·value
space· of QName requires a namespace declaration to be in scope for the
context in which QName is used."
Gabriel
!DSPAM:4045,47f3a4c970932090977483!
