[Geoserver-devel] Page Server Status with Error 500
Hi All,
I am testing GeoServer in the following environment:
O.S: Windows 10 Home (Version 21H2)
Java: OpenJDK 17.0.2
GeoServer 2.22.1 (Platform Independent Binary)
The first error I noticed was on the Status server page. When clicking on the menu, it displays the screen:
(attachments)
HTTP ERROR 500 javax.servlet.ServletException: org.springframework.web.util.NestedServletException: Handler dispatch failed; nested exception is java.lang.NoClassDefFoundError: Could not initialize class java.awt.GraphicsEnvironment$LocalGE
URI:
/geoserver/web/wicket/bookmarkable/org.geoserver.web.admin.StatusPage
STATUS:
500
MESSAGE:
SERVLET:
dispatcher
CAUSED BY:
CAUSED BY:
CAUSED BY:
### Caused by:
	at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:162)
The second mistake is when clicking on some layer in Layer Preview. It does not load the layer and the following error appears in the console:
When going back to Java 11 (JDK 11.0.2) everything works normally again.
Best regards,
Fernando Quadro
http://www.fernandoquadro.com.br
https://www.linkedin.com/in/fernandoquadro/
So JDK 17 is experimental.
Did you apply the required changes as shown at
https://docs.geoserver.org/2.22.x/en/user/production/java.html#running-on-java-17-experimental
Brad
An error like:
makes me think the server is headless, and nothing told Java that was the case. Try adding “-Djava.awt.headless=true” among the java command line parameters
and see if that helps
(attachments)
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
An error like:
See also https://gis.stackexchange.com/questions/450957/geoserver-responding-an-error-occurred-while-loading-the-page-when-pressing-bu which is related to JAva 17 an the Marlin renderer
Ian
(attachments)
Ian Turton
I applied the settings from the link below, and everything is working normally with Java 17.
Thank you all.
Best regards,
(attachments)
Fernando Quadro
