Hi all (Andrea),
There is a patch attached to this jira issue which fixes the kvp parser conflict problem. If someone could review that would be great. Thanks.
http://jira.codehaus.org/browse/GEOS-1730
-Justin
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Justin Deoliveira ha scritto:
Hi all (Andrea),
Patch looks good, only one minor thing. That commented code that you
removed in a patch is actually an optimization I wanted to submit
you and that allows to bail out of the loop as soon as the value
has been parsed. On the same topic, I guess it would be interesting
to merge the two loops in your patch so that the most likely
filter to discard a kvp parser executes first
(if (key.equalsIgnoreCase(parser.getKey())), and then the service,
version and request ones are executed.
Hmm... ok, the point of view of a performance maniac if you want...
commit the version you like best
