I have one last minute patch needed to control linearization of arcs in GeoServer.
Basically, the layer page will have a new configurable entry for curve linearization,
that will parse into a geotools Measure object.
The reason for Measure is that normally even if you have data in geographic coordinates,
you want to control the linearization accuracy in meters or feet, so the editor will allow
both raw numbers (and will use the layer native unit of measure) or something like
3m, 5ft
Internally the code will translate it to the native UOM, using the OGC (in)famous
“meters per deegree” coefficient in case the data is geographic (which is rough yes,
we can maybe make it better later by using an average value in the layer bbox
later, right now it’s not a big problem either since you cannot do curves in geodetic
coordinates in Oracle, which is the only data source supporting curves besides the
property data store)
I hope to make a pull request today, at worst tomorrow
GeoServer Professional Services from the experts! Visit http://goo.gl/NWWaa2 for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
3m, 5ft
Ing. Andrea Aime
@geowolf
Technical Lead
Want fast and easy access to all the code in your enterprise? Index and
search up to 200,000 lines of code with a free copy of Black Duck
Code Sight - the same software that powers the world’s largest code
search on Ohloh, the Black Duck Open Hub! Try it now. http://p.sf.net/sfu/bds
