I have added a module called "web-security". I also added a profile called "security" to web2 to enable the module.
I assume you are using eclipse? You run the following command from the root of the source tree:
I also added a base page which shows how to plug-in to the ui. It should be a good base point to start.
Let us know if you have any problems setting up.
Yep, can you create the structure and i commit the file after.
for the module name i think that *security* is good.
Thanks.
2008/12/19 Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>>
Hi Francesco,
Ok no problem. Shall I create the directory structure and you can
add your files into it? Or do you want to move your files over first
and then i can add the poms later. Just let me know.
-Justin
Francesco Izzi wrote:
Hi Justin,
k, the module name will be "security".
Yep, for not create any problem i want help to start the module
community.
Thanks.
<mailto:jdeolive@anonymised.com> <mailto:jdeolive@anonymised.com
<mailto:jdeolive@anonymised.com>>>
Hi Francesco,
Again no apologies needed :). One of the reasons why we use
version
control is it makes it easy to move stuff around :).
As for a name of the module how about just "security". It
might make
sense to use the module for all aspects relating to security. Or
perhaps it make sense to make it part of the core module, i
am not
sure.
As for dependencies, I think you would want to add a
dependency on
pls (or security) on web2/core, and then add a profile to
web2/app
that enables the pls module.
Let me know if you want help setting up the poms, i would be
happy
to help.
-Justin
i'm sorry for have added the module in the web2 module,
and for
this i have immediatly removed.
I wanted suggestions for module name, i thinking pls_ui.
and suggestion for dependencies.
i wont added a link in the gs-2 menu like "Per Layer
Security",
and a page that is a table of per layer security access list.
Best regards,
-- Francesco Izzi
geoSDI - NSDI
Responsabile Sviluppo Software
C.da Loja
85050 Tito Scalo - POTENZA (PZ)
Italia
phone: +39 0971427305
fax: +39 0971 427271
mob: +39 3402640314
http://geosdi.nsdi.it
Geoserver-devel mailing list
<mailto:Geoserver-devel@lists.sourceforge.net>
<mailto:Geoserver-devel@lists.sourceforge.net>>
-- Justin Deoliveira
OpenGeo - http://opengeo.org
-- Francesco Izzi
geoSDI - NSDI
C.da Loja
Italia
mob: +39 3402640314
Francesco Izzi
geoSDI - NSDI
C.da Loja
Italia
mob: +39 3402640314
