Hey All,
I just upgraded to a new machine (newer PostgreSQL, newer PostGIS, faster
CPU) and was dismayed to see my GeoServer performed a lot worse.
One of the problems turned out to be that the ST_Force_2D has been
depreciated, and now looks like this:
CREATE OR REPLACE FUNCTION postgis.st_force_2d(geometry)
RETURNS geometry
LANGUAGE sql
IMMUTABLE STRICT
AS $function$ SELECT _postgis_deprecate('ST_Force_2d', 'ST_Force2D',
'2.1.0');
SELECT ST_Force2D($1);
$function$
The outcome of this is that it is much slower, as shown:
snapmaps=# select count(st_force2d(the_geom)) from water_area;
count
927254
(1 row)
Time: 521.223 ms
snapmaps=# select count(st_force_2d(the_geom)) from water_area;
count
927254
(1 row)
Time: 4139.768 ms
A test (not particularly big) test through Geoserver:
/dev/null
real 0m2.733s
user 0m0.001s
sys 0m0.005s
Compared with a test when I have removed the call to _postgis_deprecate:
/dev/null
real 0m2.037s
user 0m0.000s
sys 0m0.006s
All commands were run multiple times to avoid any cache warming issues.
If anything maybe a warning about this needs to be put in the documentation
somewhere?
James Sewell
View this message in context: http://osgeo-org.1560.x6.nabble.com/Performance-ST-Force-2D-vs-ST-Force2D-tp5156337.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
