[Geoserver-devel] Performance versus conformance in WFS 2.0 paging
I have encountered a decision point while fixing a bug in WFS 2.0 paging:
https://jira.codehaus.org/browse/GEOS-5085
WFS 2.0 paging is implemented by specifying startindex and count (like maxFeatures in 1.1.0) in a GetFeature request. Our implementation uses the presence of startindex to detect whether paging is in use; to ensure consistency across pages, results must be sorted when paging is in use. However, this has one undesirable implication: our use of startindex is at odds with the WFS 2.0 spec, which specifies that startindex defaults to zero.
I see two options:
Option 1: Performance
- the presence of startindex triggers sorting for paging consistency
- the absence of startindex means that responses can be unsorted for greater performance
- startindex=0 and the absence of startindex are treated differently
- clients that omit startindex for their first page of paged results will get inconsistent pages (was are *assuming* that all paging clients set startindex=0 for their first page, despite this being explicitly the default in the spec)
- we will have a surprising nudge-nudge-wink-wink interpretation of the WFS 2.0 spec that differs from the tabulated default value of startindex
Option 2: Conformance
- startindex=0 has exactly the same effect as startindex not being specified
- all WFS 2.0 responses will be sorted, at the cost of performance
- we are conformant with the default values specified in the WFS 2.0 spec
So, in a nutshell, should all WFS 2.0 responses be sorted?
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
Ciao Ben, my 2 cents,
IMHO standards are beatiful as long as they are useful (i.e they make like simple or even just simpler). If by supporting a standard strictly we become unnecessarily slow, then we are less useful to users therefore the standard is failing.
This does not mean that we should ignore rules mandated by the standards.My usual suggestion in this kind of cases is to put a flag somewhere in the config to switch between strict/non strict adeherence and go for the non strict by default.
Simone Giannecchini
Ing. Simone Giannecchini
Founder
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 333 8128928
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/simonegiannecchini
http://twitter.com/simogeo
On Wed, May 16, 2012 at 6:16 AM, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> wrote:
to zero.
I see two options:
  • the presence of startindex triggers sorting for paging consistency
  • the absence of startindex means that responses can be unsorted for
    greater performance
  • startindex=0 and the absence of startindex are treated differently
  • clients that omit startindex for their first page of paged results
    will get inconsistent pages (was are assuming that all paging clients
  • we will have a surprising nudge-nudge-wink-wink interpretation of the
  • startindex=0 has exactly the same effect as startindex not being specified
  • all WFS 2.0 responses will be sorted, at the cost of performance
  • we are conformant with the default values specified in the WFS 2.0 spec
Kind regards,
Ben Caradoc-Davies Ben.Caradoc-Davies@anonymised.com
Software Engineer
Live Security Virtual Conference
Exclusive live event will cover all the ways today’s security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
Geoserver-devel mailing list
Thanks, Simone. I agree with you in principle, but there are two issues that concern me:
(1) cluttering up the configuration with options that make it more complicated
(2) adding unexpected surprised for clients, who in any case cannot know how a GeoServer instance is configured.
Kind regards,
Ben.
Simone Giannecchini
Founder
On Wed, May 16, 2012 at 6:16 AM, Ben Caradoc-Davies<Ben.Caradoc-Davies@anonymised.com<mailto:Ben.Caradoc-Davies@anonymised.com>> wrote:
to zero.
I see two options:
greater performance
Kind regards,
Ben Caradoc-Davies<Ben.Caradoc-Davies@anonymised.com>
Software Engineer
Exclusive live event will cover all the ways today's security and
Geoserver-devel@lists.sourceforge.net<mailto:Geoserver-devel@lists.sourceforge.net>
Software Engineer
zero.
I see two options:
performance
in the spec)
In a nutshell, no, we need to grow a way to tell if paging was being
asked for or not.
Ideally detect and explicit startIndex=0, less ideally a way to at
least detect if
maxFeatures was explicitly provided (if we don't have that either,
it's definitely
not paging)
Ing. Andrea Aime
Tech lead
mob: +39 339 8844549
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
asked for or not.
Can't be done. The problem is you don't know if paging is being asked for until you get the request for the next page.
First request: "Hello, please give me 1000 features" (count=1000, no startindex)
(Client sees that numberMatched>1000)
Second request: "Hello, please give me the next 1000 features" (count=1000, startindex=1000)
How can GeoServer know if the client will ever make the second request? The client may just go away. But this is also a perfectly legitimate paging use-case, where the client asks for two pages.
If GeoServer gives the client 1000 unsorted features, it will not be able to respond to the second request and maintain consistency because unsorted responses are not stable.
Kind regards,
Software Engineer
I also found this stability requirement and a rather leading hint from p41 of the WFS 2.0.0 spec (OGC 09-025r1 and ISO/DIS 19142).
7.9.2.5.4.4
Sort processing
A web feature service that receives an ad hoc query expression without a sorting clause, shall generate a
response document in which features are presented in whatever order the server chooses. However, to
comply with this International Standard, servers shall ensure that whatever order is presented when an ad hoc
query, not containing a sort clause, is first executed is preserved across subsequent executions of the same
ad hoc query expression on the same set of features.
EXAMPLE
A server may choose to sort the features by their gml:id if the client has not specified a specific sorting
clause. Subsequent invocations of the same query expression on the same set of data should result in a response
document that presents the features in the same order.
Kind regards,
Ben.
to zero.
I see two options:
greater performance
specified
Kind regards,
Software Engineer
On Wed, May 16, 2012 at 8:14 AM, Ben Caradoc-Davies
asked for or not.
Ben, it's a 7 lines mail, how could you miss the second sentence?
"less ideally a way to at least detect if maxFeatures was explicitly
it's definitely not paging)"
--> you can know if client asked for paging
Ing. Andrea Aime
Tech lead
Andrea, I didn't miss what you wrote, it just didn't make sense to me. That isn't paging; this is usually just some poor client exploring a service and not wanting to get 1.3 million features. when it can only handle 200.
Software Engineer
On Wed, May 16, 2012 at 8:56 AM, Ben Caradoc-Davies
Meh, seemed a reasonable compromise to me (I believe it would have got us
both performace and conformance in the respective typical use cases, fully paged
access and non paged one, aka download mode) but never mind.
In such case I'd prefer option 1 to be the default behavior,
option 2 to be either not there or at least something that
has to be explicitly enabled.
Ing. Andrea Aime
Tech lead
Hey guys,
My take is more or less the same as Andrea, I think we should do the following:
  1. By default with no startIndex we don’t sort
  2. By default with startIndex=0 we do sort
  3. If cite compliance is turned on we adhere strictly to the spec
Ben I share your disdain for hiding behaviour behind the cite flag but it is consistent with how many things do work today.
Also, I think it should be possible to determine if the client actually asked for paging in the underlying emf request object since it allows for “isSet()” behaviour that gives you the ability to determine if a property was set or not.
$0.02
On Wed, May 16, 2012 at 1:35 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ben, it’s a 7 lines mail, how could you miss the second sentence?
“less ideally a way to at least detect if maxFeatures was explicitly
provided (if we don’t have that either,
it’s definitely not paging)”
→ you can know if client asked for paging
Andrea, I didn’t miss what you wrote, it just didn’t make sense to me. That
isn’t paging; this is usually just some poor client exploring a service and
In such case I’d prefer option 1 to be the default behavior,
Ing. Andrea Aime
Tech lead
Justin Deoliveira
OpenGeo - http://opengeo.org
Thanks, Justin, I am happy to tick all these boxes. Updated patches in testing now.
We don't have WFS 2.0 on stable but we do have paging for WFS 1.1. I will include patches that backport a subset of these changes to stable. The main difference is that WFS 1.1 behaves as in (1) and (2) below but (3) is not applicable.
Stable will throw when anyone attempts to use startindex to sort a non-sortable data store. That is probably a good thing.
Kind regards,
Ben.
1. By default with no startIndex we don't sort
Software Engineer
Correction: a nonsortable ContentFeatureSource. Other data stores should work fine.
Software Engineer
