[Geoserver-devel] Permision to merge GEOS-8909 2.14.x backport
Hi all.
I made a pull request for [GEOS-8909] (Layer/LayerGroup order ASC on WMS GetCapabilitiesTransformer),
and the PR was reviewed and merged on master branch.
Since I sent the 2.14.x backport PR I want to ask permision for this PR to be merged.
JIRA issue link:
https://osgeo-org.atlassian.net/browse/GEOS-8909
2.14.x backport PR link:
https://github.com/geoserver/geoserver/pull/3071
Thank you.
Fernando Mino
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Fernando Mino
Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
The 2.14.0 release is currently blocked pending a couple other fixes.
Given that GEOS-8909 is strictly speaking a bug fix, and the main fix was merged to master two weeks ago, I think it is fine.
I have merged it.
Torben Barsballe
On Mon, Sep 17, 2018 at 8:55 AM fernando.mino@anonymised.com <fernando.mino@anonymised.com> wrote:
Hi all.
JIRA issue link:
Thank you.
Fernando Mino
Fernando Mino
Software Engineer
Geoserver-devel mailing list
Nice, Thanks!
Fernando Mino
Fernando Mino
Software Engineer
To: fernando.mino@anonymised.com
Cc: “geoserver-devel” geoserver-devel@lists.sourceforge.net
Date: Tue, 18 Sep 2018 10:28:44 -0700
Subject: Re: [Geoserver-devel] Permision to merge GEOS-8909 2.14.x backport
I have merged it.
Torben Barsballe
Hi all.
JIRA issue link:
Thank you.
Fernando Mino
Fernando Mino
Software Engineer
