[Geoserver-devel] permission for early backport of [GEOS-9703] Add support for StandardDeviation classification for vector data in SldService module
Dear all,
I’m writing to ask permission for early backport of [GEOS-9703] Add support for StandardDeviation classification for vector data in SldService module. The new functionality concerns the sldService module and allows to request a standardDeviation classification. No backward compatibility issue is foreseen since the stddev classification needs, to be triggered, to be explicitly requested via a request parameter.
Here the Jira ticket https://osgeo-org.atlassian.net/browse/GEOS-9703
Best regards,
Marco Volpini
+0
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
+1
In the future I would double check with the person doing the stable release this month as the mostly likely affected by an early backport. I think Ian volunteered? Or volunteer to do the release yourself …
Jody Garnett
On Fri, 14 Aug 2020, 17:54 Jody Garnett, <jody.garnett@anonymised.com> wrote:
+1
Provided its in by Tuesday morning everything should be OK
Ian
Jody Garnett
On Thu, 6 Aug 2020 at 01:44, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
+0
Simone Giannecchini
@simogeo
Founder/Director
On Thu, Aug 6, 2020 at 10:30 AM Marco Volpini <marco.volpini@anonymised.com> wrote:
Dear all,
Best regards,
Marco Volpini
Geoserver-devel mailing list
Dear All
Thanks to all for your vote.
Ian,
here is the backport:
https://github.com/geoserver/geoserver/pull/4455
I see some failures but they look unrelated, just tell me if I can help in any way.
Best regards,
C.
Mr. Carlo Cancellieri
skype: ccancellieri
Twitter: @cancellieric
LinkedIn: http://it.linkedin.com/in/ccancellieri/
Ops, apologize, it’s a different thread.
C.
skype: ccancellieri
