[Geoserver-devel] permission for early backport of[GEOS-9709] SldService, add an endpoint that returns supported classification methods
Dear all,
I’m writing to ask permission for early backport of [GEOS-9709] SldService, add an endpoint that returns supported classification methods. The new functionality introduces a new endpoint in the sldService module that returns the list of supported classification methods for both vector and raster data. No backward compatibility issue is foreseen since the addition of the new endpoint doesn’t intersect any of the already existing functionalities of the module. Here the Jira ticket https://osgeo-org.atlassian.net/browse/GEOS-9709.
Best regards,
Marco Volpini
+0
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
+1
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
mob: +39 331 6233686
