I’m writing to ask permission to backport “[GEOS-9534] Add percentages to sldService classify output”. The functionality allows to request percentages about the number of element for each class in the output when triggering a classification. A cool down month has passed and no backward compatibility issue is foreseen since the functionality is controlled by a boolean parameter set to false by default.
Here you can find the JIRA ticket https://osgeo-org.atlassian.net/browse/GEOS-9534.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
