+0
-Jukka Rahkonen-
Lähettäjä: Marco Volpini <tabareu90@…403…>
Lähetetty: keskiviikko 13. toukokuuta 2020 10.09
Vastaanottaja: Jody Garnett <jody.garnett@…403…>
Kopio: Geoserver-devel geoserver-devel@lists.sourceforge.net; Simone Giannecchini <simone.giannecchini@…1268…>
Aihe: Re: [Geoserver-devel] Permission to backport “[GEOS-9534] Add percentages to sldService classify output”
Yes the functionality concernes the classify endpoint of the sld rest service module.
Il giorno mar 12 mag 2020 alle ore 08:05 Jody Garnett <jody.garnett@…403…> ha scritto:
+1, it only adds api right?
Jody Garnett
On Mon, 11 May 2020 at 02:41, Simone Giannecchini <simone.giannecchini@…1268…> wrote:
+0
Simone GiannecchiniGeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services for more information.Ing. Simone Giannecchini
@simogeo
Founder/DirectorGeoSolutions S.A.S.
Via di Montramito 3/A
mob: +39 333 8128928http://www.geo-solutions.it
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
On Mon, May 11, 2020 at 11:33 AM Marco Volpini <marco.volpini@…1268…> wrote:
Dear all,
I’m writing to ask permission to backport “[GEOS-9534] Add percentages to sldService classify output”. The functionality allows to request percentages about the number of element for each class in the output when triggering a classification. A cool down month has passed and no backward compatibility issue is foreseen since the functionality is controlled by a boolean parameter set to false by default.
Here you can find the JIRA ticket https://osgeo-org.atlassian.net/browse/GEOS-9534.
Best regards,
Marco Volpini
Geoserver-devel mailing list
