Hi everyone,
Geoserver currently stores user and datastore connection passwords in
plaintext. This is obviously a security issue.
I have opened http://jira.codehaus.org/browse/GEOS-4702 to address
this. As Andrea noted, this needs to be discussed and digested (hehe,
sorry) a bit.
A quick overview of the goals of this issue/patch:
1) Enable password digesting for users.properties. Digesting is
one-way encryption and does not support recovery. This needs to
integrate with the existing spring security and should not effect any
external use. Existing users' passwords will be digested automagically
and new passwords handled without any changes to user interface.
2) Enable two-way encryption of datastore passwords (the passwords
often need to be provided in plaintext to the external
service/system). The upgrade should occur automagically without any
changes to the credential users. A default, low-level security option
should be provided with configurable options as well as a path to a
custom provider replacement.
3) Support (or at least have a path to) 1 and 2 for whatever new
subsystems come along that require this service.
Here is a list of discussion items:
1. The current patch adds a new dependency - jasypt
(http://www.jasypt.org/). Weighing in at a 169K, this library wraps
the core security libraries and provides spring integration (and
more). Christian's work (see 7 below) may also be using this. It may
be possible that the 'lite' version of this library could suffice.
Alternatively, the wrapper functionality and spring integration could
be replaced. I am partial to reuse myself.
2. Upgrade path - Currently, the patch will upgrade automagically and
attempt to every time. This is not a big hit for a small number of
users/storeinfos, but could be for larger numbers (e.g. lots of
shapefiles/tiffs). This is because all storeinfos need to be scanned
to detect passwords and the code for this is somewhat inefficient.
This relates to http://jira.codehaus.org/browse/GEOS-4701. An
alternative could be to refactor the upgrade code somehow to be more
efficient.
3. Release schedule (fix for version) - up in the air.
4. Default master password - currently, the default master password is
in code. An (better) alternative would be to add it to the global
configuration and generate a random one. This could potentially be a
replacement for GEOS-4701 (presence of property, blank or otherwise,
in config marks the upgrade) though I still think that the latter is
warranted.
5. Other master password options - the master password has to come
from somewhere. The earlier issue and patch
(http://jira.codehaus.org/browse/GEOS-1793) used a file based keystore
with optional password. The password, if present, would have to be
provided (of course). The 'advanced' (marginally more secure than
default password) option that is provided with the new patch is to
allow provisioning by servlet context param (more hidden than being in
global), system property, or environment variable (same). Jasypt also
supports a boot-strapping feature
(http://www.jasypt.org/webconfiguration.html) that would require more
work. A security minded user could also create a custom provider (get
the password from some other location or deliberately obfuscated code)
that would not use the above approaches. No solution will be
completely fool proof due to the problem space, but the current state
of plaintext passwords is bad - separating the master password from
the encrypted passwords is a major step up.
6. Alternative password store - the provider could even be a delegate
to external storage and retrieval of storeinfo passwords.
7. Other work - http://jira.codehaus.org/browse/GEOS-4554. Christian's
scope of work does not currently appear to address the storeinfo
issue. My intention when I started this work was to not diminish,
replace, or duplicate his efforts and I see them as fully compatible
in intention if not implementation.
Missing functionality and other issues:
1. Conversion tool - if the master password changes, the storeinfo
passwords will require re-encryption.
2. Documentation on configuration options. This includes digest
options (and implications) and master password configuration.
3. API/SPI improvement and doc
Any and all discussion welcome.
Ian Schneider
OpenGeo - http://opengeo.org
