Hi Andrea,
Hopefully not being too picky. Looks good, some minor grammatical changes.
“make next month**'s** first release” - is missing the bolded 's.
“also, it’s not possible to specifiy a custom title and abstract on LayerGroup” - I suspect that “not” should be a “now”. LayerGroup should probably be plural in that context too.
You should define GSIP the first time you use it.
In particular, now the administrator can create custom authentication chains and associated [should be associate] them to the different URLs GeoServer exposes, [semi colon here?] the improvement also made [makes] it possible to have the CAS authentication subsystem work as expected.
CAS = acronym = define.
“for you javascript development enjoyment:” [your]
“development under FAO sponsorship.” [with not under]
“manage several GeoServer installation.” [installationS]
Not claiming to be comprehensive here though.
Jonathan
On 29 January 2013 10:24, Andrea Aime <andrea.aime@anonymised.com> wrote:
I’ve just finished preparing a first version of the GeoServer 2.3 beta announcement on
the GeoServer blog. Please help me in completing and fixing it, so that we can publish
it later today (we are already one week late…)
Those that have access to the blog can edit it directly, for those that do not I’ve
attached the draft in PDF form, tell me what needs fixing here and/or attach
any screenshot you think would go with the announcement
The RC1 clock is ticking, please try to be quick.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Master Visual Studio, SharePoint, SQL, ASP.NET, C# 2012, HTML5, CSS,
MVC, Windows 8 Apps, JavaScript and much more. Keep your skills current
with LearnDevNow - 3,200 step-by-step video tutorials by Microsoft
MVPs and experts. ON SALE this month only – learn more at:
http://p.sf.net/sfu/learnnow-d2d
Geoserver-devel mailing list
Geoserver-devel@anonymised.come.net
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
