[Geoserver-devel] Please hold off pulling or pushing from github (master, 2.3.x, 2.4.x)
I made a mess with a forced push and I’m sorting this out right now. Sorry for the inconvenience.
Rini
I should have restored master to the last known point... could you check?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks Andrea. Looks alright now for master. I’ll be more careful next time.
Rini
From: andrea.aime@…403… [mailto:andrea.aime@…403…] On Behalf Of Andrea Aime
Sent: Tuesday, 21 October 2014 3:45 PM
To: Angreani, Rini (Mineral Resources, Kensington)
Cc: Geoserver-devel
Subject: Re: [Geoserver-devel] Please hold off pulling or pushing from github (master, 2.3.x, 2.4.x)
I should have restored master to the last known point… could you check?
Ing. Andrea Aime
@geowolf
Technical Lead
That looks great, Andrea. I think Rini lost one merge from yesterday on master but she can recreate it.
2.4.x needs repair. Should be reset to this:
https://github.com/geoserver/geoserver/commit/848176cc0fc8e8d5f5b1deeb7e737ff12bfc902f
which is the parent of the 2.4.8 tag:
https://github.com/geoserver/geoserver/releases/tag/2.4.8
so the commit is easy to get.
2.3.x needs repair: Should be reset to this:
https://github.com/geoserver/geoserver/commit/5decce3f8ce42d484a0e7ad4b6715c10cf43e98d
which you may have since it was yours (pngj backport).
I do not know if anyone else has a clone of this.
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Mineral Resources Flagship
Australian Resources Research Centre
I have restored 2.4.x and 2.3.x, with Ben's help.
Rini
-----Original Message-----
From: Caradoc-Davies, Ben (Mineral Resources, Kensington)
Sent: Tuesday, 21 October 2014 4:03 PM
To: Andrea Aime; Angreani, Rini (Mineral Resources, Kensington)
Cc: Geoserver-devel
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@...254...> Software Engineer CSIRO Mineral Resources Flagship Australian Resources Research Centre
On Tue, Oct 21, 2014 at 10:03 AM, Ben Caradoc-Davies <
Luckily enough, I do. Recovered 2.4.x, it seems someone else already did
the same for 2.3.x
Ing. Andrea Aime
@geowolf
Technical Lead
    https://github.com/geoserver/__geoserver/commit/__5decce3f8ce42d484a0e7ad4b6715c__10cf43e98d
    <https://github.com/geoserver/geoserver/commit/5decce3f8ce42d484a0e7ad4b6715c10cf43e98d&gt;
the same for 2.3.x
Yep, Rini had the commit in her local repo. All sorted.
Software Engineer
