[Geoserver-devel] PMC/PSC Meeting notes, November 10th 2020
GeoTools / GeoServer PMC meeting - 2020-11-10Attending
Andrea Aime
Torben Barsballe
Actions from last meeting:
   Jody to check the the GeoTools bin assembly
   Andrea marching on in the unchecked branch
Agenda
   1.
   GeoTools proposal for datastore parameters
   2.
   GT/GS November/December releases
   3.
   Travis CI letting us down
   4.
   Unchecked branch updates
Actions
   Torben: Vote on Datastore Parameter proposal
   All: Volunteer for releases - 2.18.1 in November, 2.17.4 in December
Proposal:
https://github.com/geotools/geotools/wiki/Switch-DataAccess-DataStore-parameters-map-values-from-String-to-generic-object
PR: https://github.com/geotools/geotools/pull/3195
Voting is going on.
Action: Torben to review and add vote.
https://github.com/geoserver/geoserver/wiki/Release-Schedule
2.18.1 in November
2.17.4 in December
Both missing a volunteer. Please step forward.
GeoSolutions may take one, need to discuss internally, anyone can take one
as well? Let us know.
Switch to a 10k credits and credit consumption per minute, gonna happen by
end of November.
Need to switch to something else for the Travis builds:
   Github actions. Work, worried about using only one tool, and everyone is
   switching to them.
   Circle CI, we have had mixed success with the Windows build, and there
   is a time limit (think 50 minutes). GeoNode is using CircleCI. Apparently
   we’d get 4 concurrent builds for Linux
   <https://circleci.com/blog/optimizing-open-source-projects-on-circleci/#:~:text=Parallelism%20is%20available%20if%20you,as%20they%20use%20more%20resources.&gt;
   Azure Pipelines is also an option.
   Anything else? Anyone that would like to work on a migration?
Action: Move discussion to mailing list, ask for volunteers / alternatives
GeoTools tracking:
https://docs.google.com/spreadsheets/d/1voHK_V8ZdbN-yqqUkqrl0rJsLjqiOjmVwJkm1Fjd0z4/edit
Waiting for the Datastore param proposal to be merged, then JDBC stores and
dependent modules can be fixed as well.
GeoWebCache has a ready to merge PR, no dependencies:
https://github.com/GeoWebCache/geowebcache/pull/888
GeoServer: Andrea is almost done cleaning up gs-main, will create a branch
soon.
After this, considering using IntelliJ automated cleanups to perform some
simple mass improvements like:
   assertTrue that can be replaced by assertEquals/assertSame
   Diamond operator
   Iterators vs enhanced for loop
Hi Andrea, All
We discussed this internally at GeoSolutions and we’d like to volunteer for the 2.18.1 release.
Alessandro Parma
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Alessandro Parma
DevOps Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I see that Jody already marked himself for the 2.18.1 release: https://github.com/geoserver/geoserver/wiki/Release-Schedule
Can we maybe switch roles? Like, we could do the 2.17.4 in December, or Jody might move to it instead?
Let me know.
Regards, Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Andrea, Jody,
It is usually a very busy time for us in mid Dec . @Jody would you mind if we do the 2,18.1 and you take 2.17.4 in Dec?
Alessandro Parma
Alessandro Parma
DevOps Engineer
Alessandro I am happy if you wish to do the release next week.
I was planning to do so as a token participation in the OSGeo code sprint (too little notice for us to participate as a group). I am not sure if I am available in December, too far out …
Jody Garnett
I’ll be happy to do 2.18.1 then. I guess we’ll be able to plan for 2.17.4 as the deadline approaches.
Thanks Jody
Alessandro Parma
Alessandro Parma
DevOps Engineer
thanks Alessandro:
I am interested in the 2.18.1 release and will test the artifacts as you make them.
One note with the recent update to macOS 11 … it is reported as 10.16 or something via an the older API used by OSHISystemInfoCollector in GeoServer 2.18.0:
16 Nov 08:59:33 WARN [mac.MacOSVersionInfoEx] - Unable to parse version 10.16 to a codename.
Looks like this was fixed fixed, and brought in as an updated oshi dependency late October.
Jody Garnett
