[Geoserver-devel] PngEncoder gone from KMZ
There are two classes, PngEncoder and PngEncoderB, that are missing from the code base and causing GEOS-947. They were part of the KMZ renderer.
They went missing when WCS work was merged into trunk (before 1.5 was branched). Were they removed on purpose? They are 3rd party classes but are GPL, so if licensing was the issue do we have a replacement?
Brent Owens
(The Open Planning Project)
Ciao Brent,
can you try the attached code out for the KMLEncoder?
Ciao,
Simone.
Eng. Simone Giannecchini
President/CEO GeoSolutions
Via Carignoni 51
550141 Camaiore (LU)
Mobile: +39 333 81 28928
----- Original Message ----- From: "Brent Owens" <brentowens@anonymised.com>
To: <geoserver-devel@lists.sourceforge.net>
Sent: Friday, March 02, 2007 5:10 PM
Subject: [Geoserver-devel] PngEncoder gone from KMZ
Brent Owens
opinions on IT & business topics through brief surveys-and earn cash
Geoserver-devel mailing list
(attachments)
EncodeKML.java (22.8 KB)
Licensing was not an issue with them, it's just that there's a better ways to do the same thing now.
If Simone's fix doesn't work then I'd say put them back in but make them deprecated for this next release, and then we should be able to use JAI stuff to do the same encoding.
Chris
Chris Holmes
http://topp.openplans.org
