[Geoserver-devel] polish language
I have files with polish translations of GUI (based on v.2.0.1).
Where should I send them?
There is one exception. I can't find file with strings for GWC.
Is it possible to localize it?
Grzegorz
View this message in context: http://old.nabble.com/polish-language-tp28682478p28682478.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Hi Grzegorz,
That is great. New language contributions are always welcome. The best way would probably be to create an issue in JIRA and attach the files there.
As for the translating gwc. Which parts are you attempting to localize? The ui that is part of geoserver, or the UI that gwc ships internally?
-Justin
On 10-05-26 9:38 AM, GregM wrote:
Grzegorz
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Justin,
Where are these files? I like to do the translation into Portuguese.
Best Regards,
Fernando Quadro
2010/5/27, Justin Deoliveira <jdeolive@anonymised.com>:
Hi Grzegorz,
-Justin
Grzegorz
Justin Deoliveira
Geoserver-devel mailing list
Hi Fernando,
There in svn along with the geoserver sources.
   http://svn.codehaus.org/geoserver/trunk/src/web/
Under that url there are a number of properties files:
./core/src/main/java/GeoServerApplication.properties
./demo/src/main/java/GeoServerApplication.properties
./gwc/src/main/java/GeoServerApplication.properties
./security/src/main/java/GeoServerApplication.properties
./wcs/src/main/java/GeoServerApplication.properties
./wfs/src/main/java/GeoServerApplication.properties
./wms/src/main/java/GeoServerApplication.properties
For each of those you create a GeoServerApplication_ptBR.properties with the translated keys.
@Gabriel: Can the utility you developed some time ago be used to help?
On 10-05-27 8:44 AM, Fernando Quadro wrote:
Hi Justin,
Best Regards,
Fernando Quadro
2010/5/27, Justin Deoliveira<jdeolive@anonymised.com>:
Hi Grzegorz,
-Justin
Grzegorz
Justin Deoliveira
Justin Deoliveira
Hi Fernando,
There's a community module I started some time ago intended to aid in translating the GeoServer UI <https://svn.codehaus.org/geoserver/trunk/src/community/translator&gt;
I've a bunch of uncommitted stuff though that still haven't the time to get into good shape.
Yet, if you're interested it'd be fantastic to join efforts and polish the module up for general use.
The idea behind it is that it collects the translation resources from the classpath and provides a user interface for live translation to any other language, then creates the back the bunch of .properties files for the translated language and zips them up to be sent to the geoserver developers for inclusion.
If you're interested I'll be happy to work with you on it?
Gabriel
On 5/27/10 11:48 AM, Justin Deoliveira wrote:
Hi Fernando,
Hi Justin,
Best Regards,
Fernando Quadro
Hi Grzegorz,
there.
-Justin
Grzegorz
Justin Deoliveira
Gabriel Roldan
