The main pom is broken on 1.4.x
C:\projects\geoserver\1.4.x>mvn compile
[INFO] Scanning for projects...
[ERROR] FATAL ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: unknown
POM Location: C:\projects\geoserver\1.4.x\pom.xml
Reason: Parse error reading POM. Reason: Unrecognised tag: 'executions' (position: START_TAG seen ..
.</artifactId>\r\n\t\t\t\t<executions>... @617:17)
[INFO] Trace
org.apache.maven.reactor.MavenExecutionException: Parse error reading POM. Reason: Unrecognised tag:
'executions' (position: START_TAG seen ...</artifactId>\r\n\t\t\t\t<executions>... @617:17)
at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:365)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:278)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:115)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:256)
at java.lang.reflect.Method.invoke(Method.java:324)
at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.project.InvalidProjectModelException: Parse error reading POM. Reason: U
nrecognised tag: 'executions' (position: START_TAG seen ...</artifactId>\r\n\t\t\t\t<executions>...
@617:17)
at org.apache.maven.project.DefaultMavenProjectBuilder.readModel(DefaultMavenProjectBuilder.
java:1310)
java:1270)
at org.apache.maven.project.DefaultMavenProjectBuilder.buildFromSourceFileInternal(DefaultMa
venProjectBuilder.java:414)
at org.apache.maven.project.DefaultMavenProjectBuilder.build(DefaultMavenProjectBuilder.java
:192)
at org.apache.maven.DefaultMaven.getProject(DefaultMaven.java:515)
at org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:447)
at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:351)
... 11 more
Caused by: org.codehaus.plexus.util.xml.pull.XmlPullParserException: Unrecognised tag: 'executions'
at org.apache.maven.model.io.xpp3.MavenXpp3Reader.parseReportPlugin(MavenXpp3Reader.java:358
0)
at org.apache.maven.model.io.xpp3.MavenXpp3Reader.parseReporting(MavenXpp3Reader.java:3709)
at org.apache.maven.model.io.xpp3.MavenXpp3Reader.parseModel(MavenXpp3Reader.java:2347)
at org.apache.maven.model.io.xpp3.MavenXpp3Reader.read(MavenXpp3Reader.java:4422)
java:1306)
... 17 more
[INFO] Total time: < 1 second
[INFO] Finished at: Wed Jul 05 10:24:05 CAT 2006
[INFO] Final Memory: 1M/2M
Kind Regards
Clint Lewis
