I just stumbled on this article on the net:
http://blog.klokan.cz/2008/11/png-palette-with-variable-alpha-small.html
Hum... this sounds like very very interesting, is it not?
What do you think, worth pursuing?
Andrea Aime
OpenGeo - http://opengeo.org
Having pngs that display transparent in ie 6 would be great, and half the size is definitely amazing. So yeah, worth pursuing at some point for sure. With GWC/TileCache now image size per tile is hugely important.
Andrea Aime wrote:
Chris Holmes
been there than that
The algorithm we use is a (super) optimized version of the octtree
algorithm. Notice this sentence in the documents pointed out in the
blog post:
"The quantizer is fairly slow compared to median cut or octree methods".
NeuQuant gives good quality but if you want to use it in place like we
do (the guy is doing offline preprocessing) ou'd give up a lot in
terms of speed.
I should still have around the speed tests I had made with the various
algorithms, I could put them somewhere (I have a blog as well!
Anyway, there are others novel algorithms that we could try and
implement but I wonder if ATM it is worth the effort, I think there
are many other things that we could optimize with a similar effort.
Mmmmmmhhh, probably topic for an intern.
Simone.
Eng. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Thu, Nov 13, 2008 at 8:45 PM, Andrea Aime <aaime@anonymised.com> wrote:
Andrea Aime
blog post:
terms of speed.
I agree that for the use case of online data serving having a slow
encoder is not the best option. Yet, for a tile cached set, provided
you have enough processing power to handle either the pre-seeding
or the on line tile generation, it makes sense to offset lower
performance for good quality, as the cost of producing the
tiles becomes a one time only one.
Andrea Aime
Ciao Andrea,
you are perfectly right, I did not think about this use case.
We can do this, I can resurrect my tests again, but if we then want to
make the quantization algorithm pluggable, I'd need your help for the
integration.
Do we have a deal?
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
blog post:
terms of speed.
Andrea Aime
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-devel mailing list
Ciao Andrea,
integration.
Do we have a deal?
Deal
Andrea Aime
Good to see this deal hatched
I think it’ll be an increasingly popular use case, especially as we figure out how to get GeoServer rendering tiles on EC2 and other clusters. Users will want to optimize for the smallest tiles over the fastest processing. We’ll make people happy if we give them control over optimizing for speed of response and file size, instead of pre-setting what we think is the best (though of course that should be the default).
Might be interesting to have GWC use a different quantization default from GeoServer too, since we already know the use case when people are using it.
Chris
Ciao Andrea,
make the quantization algorithm pluggable, I’d need your help for the
integration.
Do we have a deal?
Deal
Andrea Aime
This SF.Net email is sponsored by the Moblin Your Move Developer’s challenge
The code GWC uses to chop up metatiles into individual tiles is pretty trivial (see [1], createTile() and writeTileToStream() below).
Will that process kill the optimization done by GeoServer, or does the palette survive ? In the current 8 bit PNG case it appears to survive, afaict.
-Arne
1: http://geowebcache.org/trac/browser/trunk/geowebcache/src/main/java/org/geowebcache/layer/wms/WMSMetaTile.java#L142
I think it'll be an increasingly popular use case, especially as we figure out how to get GeoServer rendering tiles on EC2 and other clusters. Users will want to optimize for the smallest tiles over the fastest processing. We'll make people happy if we give them control over optimizing for speed of response and file size, instead of pre-setting what we think is the best (though of course that should be the default).
Chris
On Fri, Nov 14, 2008 at 4:20 AM, Andrea Aime <aaime@anonymised.com <mailto:aaime@anonymised.com>> wrote:
> Ciao Andrea,
want to
for the
> integration.
> Do we have a deal?
Deal
Andrea Aime
challenge
great prizes
the world
<http://moblin-contest.org/redirect.php?banner_id=100&url=/>
<mailto:Geoserver-devel@lists.sourceforge.net>
Arne Kepp
It should survive in fact... but keep me posted should you notice
anything goes wrong.
Andrea Aime
