Is it safe to merge a 2.8.x pull-request which is failing on travis due to that missing turbojpeg dependency?
On Wed, Feb 24, 2016 at 11:03 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Yeah that was pretty much my feedback, but for a community module that is having so much effort put into it (docs, backporting) you would kind of hope it was ready to be an extension soon…
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140
Geoserver-devel mailing list
Jody Garnett
On 24 February 2016 at 01:59, Andrea Aime <andrea.aime@anonymised.com> wrote:
Right, let’s see if the change to the travis config made the build
stable, if it did, I can re-kick those check jobs… although for a community
module, they are pretty much useless, the module is not going to get
built anyways.
On Wed, Feb 24, 2016 at 10:55 AM, Jody Garnett <jody.garnett@anonymised.com403…> wrote:
Thanks for checking, I can see a couple more pull requests getting the travis downcheck over this issue:
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Jody Garnett
On 24 February 2016 at 01:52, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Jody,
agreed its suspicious… the same jar is also available at the GeoSolutions maven repository:
http://maven.geo-solutions.it/org/libjpegturbo/turbojpeg-wrapper/1.2.1.1/
as well as in the boundless repo:
https://repo.boundlessgeo.com/main/org/libjpegturbo/turbojpeg-wrapper/1.2.1.1/
Unsure where the codehaus reference is coming from, the module does not have it:
https://github.com/geoserver/geoserver/blob/master/src/extension/libjpeg-turbo/pom.xml
Nor I can find a reference to that repository anywhere in the whole geoserver master checkout…
So… no clue?
On Wed, Feb 24, 2016 at 10:39 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
travis builds are failing on the following:
[INFO] GeoServer libjpeg-turbo Module … FAILURE [ 2.312 s]
[ERROR] Failed to execute goal on project gs-libjpeg-turbo: Could not resolve dependencies for project org.geoserver.extension:gs-libjpeg-turbo:jar:2.9-SNAPSHOT: Failed to collect dependencies at it.geosolutions.imageio-ext:imageio-ext-turbojpeg:jar:1.1.13 → org.libjpegturbo:turbojpeg-wrapper:jar:1.2.1.1: Failed to read artifact descriptor for org.libjpegturbo:turbojpeg-wrapper:jar:1.2.1.1: Could not transfer artifact it.geosolutions.imageio-ext:imageio-ext-library:pom:1.2-SNAPSHOT from/to codehaus-snapshots (https://nexus.codehaus.org/snapshots/): nexus.codehaus.org: Unknown host nexus.codehaus.org → [Help 1]
[ERROR]
Reference to https://nexus.codehaus.org/snapshots/ seems suspect?
I can find the artifacts here: http://download.osgeo.org/webdav/geotools/org/libjpegturbo/turbojpeg-wrapper/1.2.1.1/turbojpeg-wrapper-1.2.1.1.pom
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Daniele Romagnoli
Senior Software Engineer
