[Geoserver-devel] possible to use of GDAL extension (ecw plugin) in combi with osgeo4w64 gdal?
context:
- windows server, java 1.8.0, Tomcat, Geoserver 2.9.1 (war), gdal
extension + ecw-plugin
I have gdal/ecw working using most of info from
http://docs.geoserver.org/2.9.1/user/data/raster/gdal.html
and some other googling sources
BUT because this is also a machine to check data on, I want to install
QGIS/ogr etc etc on it (using osgeo4w installer!).
Then I thought that it should be possible to use the native gdal libs
from osgeo4w for the GDAL extension (instead of the GDAL-installer
downloaded from [0].
But failed.
While gdalinfo.exe (from osgeo4w) shows me ecw, the java gdalinfo
version (copied from the GDAL/other install) gave me a:
"no gdaljni in java.library.path" error
Copying the gdaljni from the other install in the osgeo4w bin directory
changed the error to:
"Can't find dependent libraries"
I understand that the libs from the GDAL-install are (off course) needed
by the gdaljni.dll... but I do not want to mixup the GDAL-install libs
into the osgeo4w bin dir (also because there are duplicates, and I'm not
sure about different versions).
So to make a long story short: "is it possible to use the Osgeo4W64
installed GDAL (+plugins) from within Geoserver?"
Or is there too much dependencies in gdaljni that it is too much work to
bring it to osgeo4w?
Or am I creating a problem here, and should I just install gdal twice :slight_smile:
Richard Duivenvoorde
[0]
http://demo.geo-solutions.it/share/github/imageio-ext/releases/1.1.X/1.1.15/native/gdal/windows/
What version of GDAL? We have not upgraded to GDAL 2.x yet…
On Fri, Aug 19, 2016 at 12:07 Richard Duivenvoorde <rdmailings@anonymised.com.> wrote:
context:
  • windows server, java 1.8.0, Tomcat, Geoserver 2.9.1 (war), gdal
But failed.
“no gdaljni in java.library.path” error
“Can’t find dependent libraries”
by the gdaljni.dll… but I do not want to mixup the GDAL-install libs
into the osgeo4w bin dir (also because there are duplicates, and I’m not
So to make a long story short: “is it possible to use the Osgeo4W64
installed GDAL (+plugins) from within Geoserver?”
[0]
Geoserver-devel mailing list
Jody Garnett
