I tracked down the problem in the postgis datastore to the
getTypeNames() functions:
if (namespace != null && !namespace.trim().equals("")) { //$NON-NLS-1$
st = conn.prepareStatement(
"SELECT distinct a.relname " //$NON-NLS-1$
+ "FROM pg_class a, pg_attribute b, pg_namespace c, pg_type d "
//$NON-NLS-1$
+ "WHERE a.oid = b.attrelid " //$NON-NLS-1$
+ "AND b.atttypid = d.oid " //$NON-NLS-1$
+ "AND a.relnamespace = c.oid " //$NON-NLS-1$
+ "AND c.nspname = ? " //$NON-NLS-1$
+ "AND d.typname = ? " //$NON-NLS-1$
+ "AND a.relname in (SELECT f_table_name FROM geometry_columns)"
//$NON-NLS-1$
st.setString(1, namespace);
st.setString(2, "geometry"); //$NON-NLS-1$
This assumes that the pg_namespace table is properly setup; which, I'm
sure, most people will not have.
Jody said he backed this change out.
dave
This mail sent through IMP: https://webmail.limegroup.com/
