[Geoserver-devel] PostGIS features issue
Hi guys,
I have a postgis datastore in GeoServer 1.3.0-RC4.SP1.
Trying to send the following request:
<?xml version="1.0" encoding="iso-8859-1"?> /Main/Source /Main/Year /Main/the_geom 1 40 12 56 /Main/Year 1988
GeoServer produces the following Exception:
org.geotools.data.DataSourceException: Error Performing SQL query: SELECT “ID”, “Source”, “Year” FROM “Main” WHERE ((ID = ‘234’) AND “the_geom” && GeometryFromText(‘POLYGON ((1 40, 1 56, 12 56, 12 40, 1 40))’, -1) AND “Year” = 1988)
Caused by: org.postgresql.util.PSQLException: ERROR: column “id” does not exist
Infact the SQL string is wrong, it should be:
… FROM “Main” WHERE ((“ID” = ‘234’) AND …
instead of
… FROM “Main” WHERE ((ID = ‘234’) AND …
Does anyone knows the cuse?
Alessio.
Hi Alessio,
I have tried to replicate your problem, with some sucess, however I am having a slightly different issue.
Would you be able to send me the exact definition of your table. The following pg_dump command should do it.
  pg_dump -t "Main" --schema-only [your database]
Alessio Fabiani wrote:
Hi guys,
<GetFeature outputFormat="GML2" xmlns:gml="http://www.opengis.net/gml&quot;&gt;
   <Query typeName="NURC:Main">
      <PropertyName>/Main/Source</PropertyName>
      <PropertyName>/Main/Year</PropertyName>
      <Filter>
         <And>
            <FeatureId fid="234"/>
            <BBOX>
               <PropertyName>/Main/the_geom</PropertyName>
               <gml:Box>
                  <gml:coord>
                     <gml:X>1</gml:X>
                     <gml:Y>40</gml:Y>
                  </gml:coord>
                  <gml:coord>
                     <gml:X>12</gml:X>
                     <gml:Y>56</gml:Y>
                  </gml:coord>
               </gml:Box>
            </BBOX>
            <PropertyIsEqualTo>
               <Literal>1988</Literal>
            </PropertyIsEqualTo>
         </And>
      </Filter>
   </Query>
</GetFeature>
org.geotools.data.DataSourceException: Error Performing SQL query: SELECT "ID", "Source", "Year" FROM "Main" WHERE ((ID = '234') AND "the_geom" && GeometryFromText('POLYGON ((1 40, 1 56, 12 56, 12 40, 1 40))', -1) AND "Year" = 1988)
Caused by: org.postgresql.util.PSQLException: ERROR: column "id" does not exist
... FROM "Main" WHERE (("ID" = '234') AND ...
instead of
... FROM "Main" WHERE ((ID = '234') AND ...
                                   Alessio.
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
