On Fri, Jun 19, 2015 at 10:17 PM, Jody Garnett <jody.garnett@anonymised.com>
wrote:
That is fascinating Andrea. Wonder if we could add the small outline in
cases where a stroke has not been supplied (and fill opacity is 100%) so
that this glitch in Java2d is masked over for our users.
I'm skeptical about going this way, it can have a measurable performance
overhead and the glitch is visible only against polygon partitions, but
not against isolated polygons (e.g., building maps)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
