FYI,
I accidentally had an experience using geoserver on postgis without GEOS support (I forgot to enable it when I compiled postgis). Before I enabled it, I never got a result back from geoserver, things just appeared to go and go. After I enabled it, everything was tickety-boo.
Thank god there was a big "you don't have GEOS!" warning in the log, or I could have spent hours trying to figure out what was wrong with *UDIG* (Turns out, it was fine.)
Paul
On Tue, 14 Jun 2005, Paul Ramsey wrote:
FYI,
What version of PostGIS/Postgresql was it? Could you add that info to the
jira? http://jira.codehaus.org/browse/GEOS-362 I know this worked on
older versions, and I heard there were quite a few changes between 0.8 and
1.0...
Paul
SF.Net email is sponsored by: Discover Easy Linux Migration Strategies
from IBM. Find simple to follow Roadmaps, straightforward articles,
informative Webcasts and more! Get everything you need to get up to
speed, fast. http://ads.osdn.com/?ad_id=7477&alloc_id=16492&op=click
Geoserver-devel mailing list
This was against PostGIS version 1.0, pgSQL version 8.0.
Paul
FYI,
Thank god there was a big "you don't have GEOS!" warning in the log, or I could have spent hours trying to figure out what was wrong with *UDIG* (Turns out, it was fine.)What version of PostGIS/Postgresql was it? Could you add that info to the jira? http://jira.codehaus.org/browse/GEOS-362 I know this worked on older versions, and I heard there were quite a few changes between 0.8 and 1.0...
Paul
