I see, thanks for the clarification.
I will try to take a look at that this week.
On 10/02/2017 12:34 PM, Ben Caradoc-Davies wrote:
On 02/10/17 22:24, Nuno Oliveira wrote:
On 10/01/2017 01:26 AM, Ben Caradoc-Davies wrote:
I also saw stale dependencies in activemqBroker if anyone cares enough to fix them.
Thanks for the check, but I don't understand what you mean by stall dependencies ? you mean dependencies versions that are hard-coded ?
Yes. The activemqBroker pom has an unmanaged dependency (hardcoded) on a postgresql 8.3-603.jdbc4 jar that is much older than the 42.1.1 used in the rest of the project (a stale dependency). This dependency is used when the "postgres" profile is active. I would have upgraded it but I do not know how to test.
geogig is easier because it was already using 42.1.1 and only needs to switch from hardcoded to managed, but I thought it best to ask the module maintainer as I am not familiar with the module and its dependencies.
Kind regards,
Nuno Oliveira
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
