Hi All,
I discussed this a little with Andrea and I believe that, and here is
my feedback.
Baseline is, we should strive to keep quality high. When I talk to end
users in the real world, none of them is happy about the release
early, release often thing they are happier "this works without
issues" thing.
So, IMHO:
-1- we should account for reviews in the GSIP process, although we
don't want that for each individual fix but for larger, new
functionalities, yes we should.
-2- accounting for reviews should not lead to delays for who is
proposing the change. So there should be a fixed windows for reviews
So I am fine with something along what Ben proposes:
- I can say I'd like to review
- I have to do it within 1W at most, that time passed the proposer can
hit the merge button (or someone con do it for him)
Feedback?
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Wed, Aug 10, 2016 at 3:31 AM, Andrea Aime
<andrea.aime@anonymised.com> wrote:
On Tue, Aug 9, 2016 at 10:48 PM, Ben Caradoc-Davies <ben@anonymised.com>
wrote:
Andrea,
we raised this problem in the committee meeting. Rather than a mandatory
delay, we could add an "interested parties" section to each GSIP so that
those wanting to do so could advertise their desire to review pull requests
for the GSIP. We could add a rule to the GSIP procedure that all subscribers
listed in the "interested parties" section must be given a week (or two if
requested?) to review pull requests, even after the pull request is
accepted. This would allow clearer communication of interest and
availability.
Hi Ben,
it's interesting that you name it a "mandatory delay", given my experience
with pull requests related to GSIPs and new functionality
in general that sounds more like a mandatory speedup, I hardly see any pull
request of significance being handled within the week (normally
because we allow others to have a look at it before merging).
Indeed, to make a parallel, the week long rules about voting on the
proposals were meant to avoid long delays, not to force a slowdown.
The particular context here spins it as a delay because we have just
experience something novel, a GSIP related
pull request being merged so quickly that "interested parties" did not even
have time to check their availability, let alone do a review.
Allowing a bit of time to review a GSIP related pull request is important,
for a number of good reasons:
If the proposal was high level, details that might spun acceptance one way
or the other can only be seen in code. The PSC should be allowed to check
what actually happened code wise in this case.
If the the proposal was detailed and low level, actual implementation could
have diverged from it in some respect, normally because hitting the actual
code brings insight not available when writing the proposal. While it would
be too much to go back, change the proposal, and vote again based on
implementation results, the PSC should be allowed to check the divergence is
not so significant as to make the proposal invalid.
If something is proposal worthy, it's likely touching highly visible
portions of the user experience, or core code, so it's only natural that we
should check whether it's affecting backwards compatibility, performance and
stability.
Generally speaking, it should be natural that if a pull request is related
to GSIP, it should go though more scrutiny, instead here we have some party
claiming that "it was voted on", so it can go in even as fast, if not
faster, than the average pull request. But as I said, if you check the pull
request queue, you'll find that changes of any significant often take more
than a week to be reviewed.
What I'm trying to push for is actually a process that's quicker than our
"tradition", disallowing "flash merges" but also setting up some
fairness/level playing field.
Give the above, having to explicitly specify "interested parties" does not
seem like a good way to go, as the PSC is the "interested party" by
definition of GSIP.
Taking GSIP-149 as an example, the pull request is not small (40 files
changed) and diverges from the GSIP by downgrading to "not implemented nice
to haves" some bits that were official part of the proposal (see description
at https://github.com/geoserver/geoserver/pull/1748 and compare to
https://github.com/geoserver/geoserver/wiki/GSIP-149) .
Personally I don't think the latter is a problem (but it's just me, others
might have a different opinion), although I'm surprised to see that the CSS
editor pages are still there (the proposal states "the CSS Styles page would
be deleted from the CSS Styling extension") and that no documentation has
been updated (but the style editor works in a significantly different way
now, so doc updates are actually mandatory).
Tomorrow (well, actually later today, it's Wednesday already here) I'll try
to check the actual code changes, but now that the pull request has been
merged, will there be any incentive to address the review?
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
not give any warranty or accept liability as the content, accuracy or
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. http://sdm.link/zohodev2dev
Geoserver-devel mailing list
