[Geoserver-devel] Preferred JDK for geoserver 2.7?
I'm updating the src/README
There is one change that I'd like to get confirmation on - what the preferred
JDK is for GeoServer (say, from 2.7 onwards).
At the moment, relevant part of the patch would look like:
GeoServer needs a Java SDK, maven (version 3 is recommended) and git.
-While compiling GeoServer with OpenJDK 6 and 7 works now, Sun's JDK 6 is
still the recommendation.
-Under Debian/Ubuntu simply run:
+While compiling GeoServer with OpenJDK 6 and 7 works now, Oracle's JDK 7 is
+Under Ubuntu simply run:
+sudo apt-get install python-software-properties
+sudo add-apt-repository ppa:webupd8team/java
+sudo apt-get update
+sudo apt-get install oracle-java7-installer maven git
+On other distributions, OpenJDK, maven and maven will almost certainly be
packaged. See
+http://www.oracle.com/technetwork/java/javase/downloads/index-jsp-138363.html#javasejdk
+to download Oracle JDK if necessary.
-sudo apt-get install sun-java6-jdk maven git
-or
-sudo aptitude install sun-java6-jdk maven git
Its also up at github if that is an easier way to make markup:
https://github.com/bradh/geoserver/commit/19af582190a484a49382349edfc483a68bbd268b
Brad
This came up in code sprint, here is resulting page http://docs.geoserver.org/latest/en/user/installation/java.html
Jody Garnett
On Mon, Sep 22, 2014 at 2:14 PM, Brad Hards <bradh@anonymised.com> wrote:
I’m updating the src/README
There is one change that I’d like to get confirmation on - what the preferred
-While compiling GeoServer with OpenJDK 6 and 7 works now, Sun’s JDK 6 is
+While compiling GeoServer with OpenJDK 6 and 7 works now, Oracle’s JDK 7 is
packaged. See
-or
Brad
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
