[right list this time]
What is the preferred way to include an optional/unsupported module in
geoserver.war? I have a local modification to web/pom.xml that adds a
dependency on gt-app-schema when profile "app-schema" is active. Thus
building geoserver/src with
mvn -Papp-schema install
result in a deployment bundle (web/target/geoserver.war) that contains
the gt-app-schema jar.
Is this the preferred approach? If so, can I submit this change for
inclusion in web/pom.xml?
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer, CSIRO Exploration and Mining
Australian Resources Research Centre
26 Dick Perry Ave, Kensington WA 6151, Australia
One alternative would be to have a community module like web, or that depends on web.
The likely tradeoff is between simplicity of maintenance (profile in web) and keeping special-interest cruft out of the web/pom.xml (exiled to community).
Preference? A third way?
Hi Ben
Yes, the preferred approach is to use a profile. So +1 on committing the profile to web/pom.xml (and I assume community/pom.xml).
As a convention we try to keep the profile name the same as the community module name, which it looks like you have.
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
Thanks, I will submit a patch for web/pom.xml and modify community/pom.xml when I create community/app-schema. (I'll be back in the new year.)
Yes, I think I prefer this approach, after my experiences in the 1.6.x community area ...
-Justin
