Hello
I was trying to configure an app-schema to deliver WOML features.
I’m able to deliver WFS with womlcore and womlswo elements, but when I try to map some GML elements I get the following result:
<ows:ExceptionReport version=“2.0.0” xsi:schemaLocation=“http://www.opengis.net/ows/1.1 http://localhost:8080/geoserver/schemas/ows/1.1.0/owsAll.xsd”>
<ows:Exception exceptionCode=“NoApplicableCode”>
ows:ExceptionTextjava.io.IOException: The prefix "null" for element "null:name" is not bound.
</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
I’m using Geoserver 2.2 SNAPSHOT
This is the mapping file:
<as:AppSchemaDataAccess xmlns:as=“http://www.geotools.org/app-schema”
xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance”
xsi:schemaLocation=“http://www.geotools.org/app-schema AppSchemaDataAccess.xsd”>
gml
http://www.opengis.net/gml/3.2
womlswo
http://xml.fmi.fi/namespace/woml/swo/2011/11/15
womlcore
http://xml.fmi.fi/namespace/woml/core/2011/11/15
datastore
directory
file:./
…/…/…/schemas/catalog.xml
http://xml.fmi.fi/schema/woml/swo/2011/11/15/woml-swo.xsd
http://xml.fmi.fi/schema/woml/core/2011/11/15/woml-core.xsd
datastore
womlswo_ColdFront
womlswo:ColdFront
womlswo:ColdFront
getId()
gml:name
'test'
womlcore:shortInfo
'test2'
Alessando,
your mapping file is schema-invalid. targetTypes should contain only one FeatureType which can contain multiple schemaUri elements. (At this point a nonvalidating parser is used; I'm not sure if it ignores the second FeatureType.)
Kind regards,
Ben.
On 31/01/12 22:10, alessandro marrone wrote:
Hello
<ows:ExceptionReport version="2.0.0" xsi:schemaLocation="http://www.opengis.net/ows/1.1 http://localhost:8080/geoserver/schemas/ows/1.1.0/owsAll.xsd">
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>java.io.IOException: The prefix"null" for element"null:name" is not bound.
</ows:Exception>
<as:AppSchemaDataAccess xmlns:as="http://www.geotools.org/app-schema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.geotools.org/app-schema AppSchemaDataAccess.xsd">
<namespaces>
<Namespace>
<prefix>gml</prefix>
<uri>http://www.opengis.net/gml/3.2</uri>
</Namespace>
<Namespace>
<prefix>womlswo</prefix>
<uri>http://xml.fmi.fi/namespace/woml/swo/2011/11/15</uri>
</Namespace>
<Namespace>
<prefix>womlcore</prefix>
<uri>http://xml.fmi.fi/namespace/woml/core/2011/11/15</uri>
</Namespace>
</namespaces>
<sourceDataStores>
<DataStore>
<id>datastore</id>
<parameters>
<Parameter>
<name>directory</name>
<value>file:./</value>
</Parameter>
</parameters>
</DataStore>
</sourceDataStores>
<catalog>../../../schemas/catalog.xml</catalog>
<targetTypes>
<FeatureType>
<schemaUri>http://xml.fmi.fi/schema/woml/swo/2011/11/15/woml-swo.xsd</schemaUri>
</FeatureType>
<FeatureType>
<schemaUri>http://xml.fmi.fi/schema/woml/core/2011/11/15/woml-core.xsd</schemaUri>
</FeatureType>
</targetTypes>
<typeMappings>
<FeatureTypeMapping>
<sourceDataStore>datastore</sourceDataStore>
<sourceType>womlswo_ColdFront</sourceType>
<targetElement>womlswo:ColdFront</targetElement>
<attributeMappings>
<AttributeMapping>
<targetAttribute>
womlswo:ColdFront
</targetAttribute>
<idExpression>
<OCQL>getId()</OCQL>
</idExpression>
</AttributeMapping>
<AttributeMapping>
<targetAttribute>
gml:name
</targetAttribute>
<sourceExpression>
<OCQL>'test'</OCQL>
</sourceExpression>
</AttributeMapping>
<AttributeMapping>
<targetAttribute>
womlcore:shortInfo
</targetAttribute>
<sourceExpression>
<OCQL>'test2'</OCQL>
</sourceExpression>
</AttributeMapping>
</attributeMappings>
</FeatureTypeMapping>
</typeMappings>
</as:AppSchemaDataAccess>
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
