[Geoserver-devel] preflight testing for 2.7.0
Build is available for preflight testing:
http://ares.boundlessgeo.com/geoserver/release/2.7.0/
I am going to download the mac bits and build a DMG.
Jody Garnett
Windows looks good.
On Fri, Mar 20, 2015 at 1:12 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Dive into the World of Parallel Programming The Go Parallel Website, sponsored
by Intel and developed in partnership with Slashdot Media, is your hub for all
things parallel software development, from weekly thought leadership blogs to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
Geoserver-devel mailing list
Travis Brundage
Software Engineer | Boundless
tbrundage@anonymised.com
250.888.2820
@boundlessgeo
Jody,
the demo request WCS_getCoverage.xml fails. There is no mention of this coverage in the capabilities. I do not usually test this so do not know if it is a new problem. Everything else seemed to work.
2015-03-21 09:48:48,198 ERROR [geoserver.ows] -
org.vfny.geoserver.wcs.WcsException: Cannot find sourceCoverage nurc:Pk50095 in the catalog!
  at org.geoserver.wcs.DefaultWebCoverageService100.getCoverage(DefaultWebCoverageService100.java:173)
Kind regards,
Ben.
Jody Garnett
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz>
New Zealand
And mac also.
On 20 March 2015 at 13:27, Travis Brundage <tbrundage@anonymised.com> wrote:
Windows looks good.
Jody Garnett
Jody Garnett
Travis Brundage
250.888.2820
@boundlessgeo
Go team!
Even though artifacts are posted, I'd like to suggest that we hold off publishing the announcement until Monday AM, where it's more likely to get noticed (less likely to be buried in someone's news feed).
Mike
Mike Pumphrey
User Advocate | Boundless
mike@anonymised.com
http://boundlessgeo.com
@boundlessgeo
On 3/20/2015 1:27 PM, Travis Brundage wrote:
Windows looks good.
Jody Garnett
sponsored
all
to
I forgot to mention my platform:
debian/sid
openjdk-7-jdk:amd64 7u75-2.5.4-3 amd64
I tested the war.zip then installed the app-schemas plugin and tested the app-schema tutorial configuration.
Director
New Zealand
Sigh - you are correct Mike (this was in our release guide at some point). Especially with a major release we should go for max publicity.
On 20 March 2015 at 14:00, Mike Pumphrey <mike@anonymised.com> wrote:
Go team!
Even though artifacts are posted, I’d like to suggest that we hold off publishing the announcement until Monday AM, where it’s more likely to get noticed (less likely to be buried in someone’s news feed).
Mike
Mike Pumphrey
mike@anonymised.com
@boundlessgeo
Windows looks good.
Jody Garnett
sponsored
all
to
Geoserver-devel@anonymised.comsourceforge.net
Jody Garnett
That layer is disabled (if you go to the layer list). So it is not expected to work.
Changing to nurc:Arc_Sample works.
debian/sid
Director
New Zealand
Jody Garnett
Sorry changing to nurc:Arc_Sample works with DescribeCoverage (I am not good at hand crafting WCS request)
Jody Garnett
Jody Garnett
debian/sid
Director
New Zealand
Hi Ben,
I think that the request is OK but the store "img_sample2" installs as disabled. It has been so since long. And with Firefox it can't be switched into enabled because of a UI bug.
-Jukka-
________________________________________
Lähettäjä: Ben Caradoc-Davies <ben@anonymised.com>
Lähetetty: 20. maaliskuuta 2015 22:57
Vastaanottaja: Jody Garnett; geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] preflight testing for 2.7.0
Jody,
        at
Kind regards,
Ben.
Jody Garnett
Director
New Zealand
On Fri, Mar 20, 2015 at 10:28 PM, Rahkonen Jukka (MML) <
jukka.rahkonen@anonymised.com> wrote:
Hi Ben,
Can we open a ticket and fix this for 2.7.1? It has been like that for
quite some time, no enough of a reason to block 2.7.0 imho
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
