I’m starting a thread to get us prepared to the Wicket upgrade sprint in January.
We’ll have several devs and testers for a limited amount of time, thus it makes
sense to do some preparation in advance in order to hit the ground running,
and leverage all the people we have starting from the first morning of coding.
My plan is to create a wicket7 branch on GeoServer’s github, update the
deps, and perform some of the changes that can be machine automated,
in order to spend time during the sprint on the bits that actually require some
brain to be performed.
I don’t know in advance all the changes that can be automated, but my two
previous attempts at upgrading wicket, to 1.5 the first, to 1.6 (wicket 6) the
second, provide some good starting point to locate changes that repeat
over and over, and also, could be used as quick guidance when in doubt
during the sprint:
https://github.com/geoserver/geoserver/commits/feature-upgrade-wicket16
Another thing that I would like to do, if I manage, is to drop the dependency
towards wicket-spring, since the latter depends on Spring 4, we are not
using much out of that module anyways, and during one of my upgrade
attempts I already made GeoServerApplication not extend SpringWebApplication
anymore.
Other changes that are suitable to be done earlier are anything so core
that would prevent individual component tests from being run.
Other activities that could be carried on early would be checking
library compatibility, some Java 8 lambda support and tester improvement guides.
Library compatibility wise, we should check that we don’t need to upgrade
other libs in order to upgrade Wicket. As far as I can tell Wicket core
does not depend on much, but we should probably have a look:
http://mvnrepository.com/artifact/org.apache.wicket/wicket-core/7.1.0
The lambda support would reduce the usual Wicket boilerplate, we could draw
some ideas from these blogs/projects:
https://rodrigouchoa.wordpress.com/2015/02/26/apache-wicket-with-lambda-expressions/
https://github.com/rodrigouchoa/wicket-lambda
https://github.com/todvora/wicket-lambdamodel
https://github.com/wicketstuff/core/tree/master/lambda-parent/lambda
A thorn in the back when working with Wicket is the testing, which has been
so far, with Wicket 1.4, poor and hard to get right to say the least.
It would be cool if someone could look into what Wicket 7 has to offer,
and if there is anything useful, write down a little guide on how to perform
test upgrades. Some reference here:
https://ci.apache.org/projects/wicket/guide/7.x/guide/testing.html
Hum… that’s what comes to mind right, you’re welcomed to contribute more
bits to the list, and more importantly, to volounteer on working on an item
of your choice.
Don’t think I’ll get quick feedback today, but I’m going to get a wicket7 branch
started, will mail back when it’s available.
Geosolutions’ Winter Holidays from 24/12 to 6/1
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
