[Geoserver-devel] Print module/extension and GSIP 110
Hi List,
I was wondering as to the state of the Print Module and GSIP 110. Unfortunately due to the website transfer the URL that search engines return is currently a 404.
I see that it’s an extension on Ares for master (2.6.x), but a community module in 2.5.x. Is it going to be backported to 2.5.x?
Also, which version of MapFish Print are the versions using (the 2.5.x and 2.6.x)? I believe there was an interest in getting that updated to use MFP 2.0, did that happen.
Jonathan
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Sorry, Justin moved the wiki but did not update the website link(s).
Here is the corrected link to GSIP 110: https://github.com/geoserver/geoserver/wiki/GSIP%20110%20-%20Promoting%20the%20Printing%20community%20module%20to%20extension
Jody Garnett
On Thu, Jun 12, 2014 at 7:14 PM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Hi List,
Jonathan
HPCC Systems Open Source Big Data Platform from LexisNexis Risk Solutions
Find What Matters Most in Your Big Data with HPCC Systems
Open Source. Fast. Scalable. Simple. Ideal for Dirty Data.
Leverages Graph Analysis for Fast Processing & Easy Data Exploration
http://p.sf.net/sfu/hpccsystems
Geoserver-devel mailing list
Hi Johnathan,
2014-06-12 11:14 GMT+02:00 Jonathan Moules <jonathanmoules@anonymised.com>:
The module has been promoted to extension only on master for the moment, and there it uses mapfish-print 2.0.0.
We are waiting for some bug fixes to be deployed on a 2.0.1 (the fixes are already on mapfish-print master, but we are waiting for an official release to include it), hopefully before the final 2.6 is out.
I was waiting for those bug fixes before asking for backport, because they are quite important (expecially one that is about thread leaks in the printer servlet).
You can find the nightlies for master here: http://ares.boundlessgeo.com/geoserver/master/
If you look at the ext-* folders you will find the extension using mapfish-print 2.0.
Mauro
Hi Both,
Thanks for the links and information. We’ve got one or two bugs we’d like fixed in MFP too, so I guess we should pursue the if we want them in MFP 2.0.1 and GeoServer.
Thanks again,
Jonathan
On 12 June 2014 10:25, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
Hi Johnathan,
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
Mauro
