Hello,
Well, I posted this question yesterday but maybe I didn't make myself clear.
There it goes again...
I have some shapefiles that describe the streets of a given city. Well, with
some viewers I can choose an attribute to print its value over the streets
(which is the street names - each street with its respective name). However,
I couldn't find a way to tell the renderer I'd like to choose an attribute
to be rendered with the polygons so that I would have the picture of the
streets and their names... Is it possible?
Thanks in advance.
Calegari San
Yes, you have to create a style with two symbolizer, one line simbolizer
for the streeet itself, and text symbolizer that uses the attribute as the
label.
An XML style gui builder is in the works, but I don't know when I will find
the time to finish it.
Best regards
Andrea Aime
Aurélio Calegari wrote:
Hello,
Thanks in advance.
Calegari San
The SF.Net email is sponsored by EclipseCon 2004
Premiere Conference on Open Tools Development and Integration
See the breadth of Eclipse activity. February 3-5 in Anaheim, CA.
http://www.eclipsecon.org/osdn
Geoserver-devel mailing list
Thanx Andrea!
Is there a documentation of these styles. I have created some styles, but I
think there should be a "how to..." document or something like! Do you know
where I can find it. It's not really necessary an IDE, but just the
description of the XML tags and usage.
Thanks again
Calegari San
----- Original Message -----
To: "Aurélio Calegari" <aurelio@anonymised.com>
Cc: <geoserver-devel@lists.sourceforge.net>
Sent: Tuesday, January 20, 2004 9:03 AM
Subject: Re: [Geoserver-devel] Printing layers and its labels
label.
find
Best regards
Andrea Aime
> Hello,
clear.
with
streets
However,
attribute
> Thanks in advance.
> Calegari San
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Thanx Andrea!
We have followed the SLD (Styled Layer Descriptor) specification by OpenGis,
so go to the opengis site and download the SLD specification.
Best regards
Andrea Aime
At 13:33 20/01/2004, Aurélio Calegari wrote:
Thanx Andrea!
If you look in the GeoTools2 renderer-styling module you'll see some examples of how the styling works.
I've included the text test sld code and an image of the output.
Hope that helps
Ian
(attachments)
sample.sld (22.7 KB)
Thanks Ian…
It was really quite usefull. Well, I also took a glance of the SLD specs and built the following XML:
Ruas desbotadas por Aurelio Calegari
The title of the layer
A styling layer used for the unit tests of sldstyler
polyshp
feature
#C1873D
1
**NAME**
**Serif**
**10**
**#000000**
The red-highlighted text is what’s new in my XML, however the result is something like:
Well, then observing your example, I replaced the blue-highlighted text in the above XML by: NAME
And what I expected took place in this case:
Lot’s of name… But a question remains… The name of the parameter I want ot print is “Name”, as defined in my SHP file. Take a look bellow:
Do you have any idea about what might be going wrong onde I can get the real name attributes printed in the image?
Thanks again
Aurelio
To: “Aurélio Calegari” <aurelio@anonymised.com>
Sent: Tuesday, January 20, 2004 10:41 AM
Thanx Andrea!
think there should be a “how to…” document or something like! Do you know
where I can find it. It’s not really necessary an IDE, but just the
If you look in the GeoTools2 renderer-styling module you’ll see some
I’ve included the text test sld code and an image of the output.
Hope that helps
Ian
Thanks again
Aurelio
Wild guess: case sensitivity. The rendering code does not know that the
dbf attribute names are case independent, so I guess that the name
in the DBF file is not "NAME", but maybe "Name", "name", whatever....
I may just be plain wrong thought...
Best regards
Andrea Aime
Well, then observing your example, I replaced the blue-highlighted text in the above XML by: <Label><Literal>NAME</Literal></Label>
Lot's of name... But a question remains... The name of the parameter I
want ot print is "Name", as defined in my SHP file. Take a look bellow:
The SLD experts may correct me, but since they aren't answering, in my
glance at the sld spec I think the xml should maybe be
<Label><PropertyName>NAME</PropertyName></Label>
instead of:
This guess is more from my Filter spec knowledge, so I may be missing
something, but you should give it a try. The PropertyName might be case
sensitive, so maybe try out <Label><PropertyName>name</PropertyName></Label>
as well.
Chris
Thanks again
Aurelio
>Thanx Andrea!
Hope that helps
Ian
Hi Chris
I made that... And I couldn't get that attribute printed in the generated pic.
So, I changed to <Literal> in order to check if I could have the literal "NAME" printed. In this case it worked, but not with
<PropertyName/> tag.
This problem is still happening.
Thanx anyway
Aurelio
Cc: "Ian Turton" <i.turton@anonymised.com>; <geoserver-devel@lists.sourceforge.net>
Sent: Wednesday, January 21, 2004 1:28 PM
instead of:
as well.
Chris
> Thanks again
> Aurelio
> From: "Ian Turton" <i.turton@anonymised.com>
> >Thanx Andrea!
> Hope that helps
> Ian
