Uhm… it could be, and it could also be the reason for the test randomly failing.
I should check the default config.yaml (printing template), that probably references external resources, and is used by that test.
I think I should try to use a different template for testing purposes.
Mauro
2014-04-22 12:13 GMT+02:00 Jody Garnett <jody.garnett@anonymised.com>:
This makes me sad:
T E S T S
Running org.geoserver.printing.PrintDemoPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.094 sec
Running org.geoserver.printing.SmokeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 138.648 sec
Is there something obvious I am doing wrong? Or is SmokeTest hitting up a slow external resource?
Jody Garnett
Start Your Social Network Today - Download eXo Platform
Build your Enterprise Intranet with eXo Platform Software
Java Based Open Source Intranet - Social, Extensible, Cloud Ready
Get Started Now And Turn Your Intranet Into A Collaboration Platform
http://p.sf.net/sfu/ExoPlatform
Geoserver-devel mailing list
