It earlier claims to build the user-pdf correctly.
So my questions are:
do we still build the pdf?
Yes we should, think last release Jody had issues and skipped it.
what is the maven magic to do this? I can’t get a PDF built locally
Err… I guess it’s a straight call to the sphinx machinery
is pdflatex present on the build server? as this would probably generate this issue?
And that alone is not enough, one need kind of the fullest latex installation package available
(at least, that was needed last time I built it locally)
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.ithttp://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I’ve managed to fix the release configuration it was missing pdflatex - for future reference the magic command is sudo apt-get install -y texlive-base texlive-latex-recommended texlive-science texlive-latex-extra texlive-extra-utils.
Also the workflow doc needs updating as there is no make file any longer, that magic command is ant user-pdf I’ll try to get to that later today.
I’ll add that to the startup script for the Jenkins worker next time I update it, so that it doesn’t have to be included in the release job (reconstructing exactly what packages are needed to build everything has been a bit of an adventure).
