I don’t really know about the new labeler, but the old one was able to render arabic labels correctly… There is good case, and sample shape file in http://jira.codehaus.org/browse/GEOS-1369 — On Sat, 1/17/09, Justin Deoliveira jdeolive@anonymised.com wrote: > From: Justin Deoliveira jdeolive@anonymised.com > Subject: Re: [Geoserver-devel] Problem in Rendering Arabic Labels > To: “Ahmad Al-Obaidy” ahmad@anonymised.com > Cc: “Andrea Aime” aaime@anonymised.com, geoserver-devel@lists.sourceforge.net > Date: Saturday, January 17, 2009, 12:50 AM > > Hmmm… I wonder if this is a regression that has come out of using the new labeler? > > Ahmad Al-Obaidy wrote: > > The bug seems to exists again in the gt-2.5 ![]() > > > > — On Mon, 10/8/07, Andrea Aime /aaime@anonymised.com/ wrote: > > > > > > From: Andrea Aime aaime@anonymised.com > > Subject: Re: [Geoserver-devel] Problem in Rendering Arabic Labels > > To: “Ahmad Al-Obaidy” ahmad@anonymised.com > > Cc: geoserver-devel@lists.sourceforge.net > > Date: Monday, October 8, 2007, 7:57 PM > > > > Ahmad Al-Obaidy ha scritto: > > > Hi Andrea, > > > Thank you for being interested… > > > > > > I can gratefully provide sample data, the expected output and > > test any patch… > > > > > > And even try to fix it out with some help > > > > > > As for the problem, I think it came from the Geotools LiteRenderer… > > > > > > I tried to hack the code… And it seems LiteRenderer is using > > Graphics2D for rendering maps… > > > I tested the Graphics2D and it work just fine with Arabic text > > using drawString… > > > > > > I didn’t figure out the code responsible for draw labels… but > > what I had conclude is LiteRenderer is rendering each letter > > separately… and this bring the problem in… > > > > > > Because Arabic text is written in script manner and from right to > > left rather than in separate manner and left to right like Latin > > alphabets… > > > > Ahmad, > > in GeoTools we cannot use drawString directly because we need a set > > of informations that only GlyphVector can provide (we use them to draw > > halos, and to perform label collision detection and avoidance). > > The method we were using so far to build worked for most fonts, but > > not for Arabic and a few others. I tried to fix it without giving up > > too much performance in the western case, but I’m not sure about the > > results. > > > > Can you have a look at > > http://jira.codehaus.org/secure/attachment/29786/arabic.png (attached to > > http://jira.codehaus.org/browse/GEOS-1369) and tell me if this is fine? > > > > Cheers > > Andrea > > > > > > ------------------------------------------------------------------------ > > > > ------------------------------------------------------------------------------ > > This SF.net email is sponsored by: > > SourcForge Community > > SourceForge wants to tell your story. > > http://p.sf.net/sfu/sf-spreadtheword > > > > > > ------------------------------------------------------------------------ > > > > _______________________________________________ > > Geoserver-devel mailing list > > Geoserver-devel@lists.sourceforge.net > > https://lists.sourceforge.net/lists/listinfo/geoserver-devel > > – Justin Deoliveira > OpenGeo - http://opengeo.org > Enterprise support for open source geospatial. |
Actually maybe it is not the new labeller... I believe it is only the default in the up coming 1.7.2 release. Regardless... andrea should be able to better comment.
-Justin
I don't really know about the new labeler, but the old one was able to render arabic labels correctly...
To: "Ahmad Al-Obaidy" <ahmad@anonymised.com>
Cc: "Andrea Aime" <aaime@anonymised.com>,
Date: Saturday, January 17, 2009, 12:50 AMHmmm... I wonder if this is a regression that has come out of using
> --- On *Mon, 10/8/07, Andrea Aime /<aaime@anonymised.com
</mc/compose?to=aaime@anonymised.com>>/* wrote:
> From: Andrea Aime <aaime@anonymised.com
</mc/compose?to=ahmad@anonymised.com>>
</mc/compose?to=geoserver-devel@lists.sourceforge.net>
> > Hi Andrea,
> > Thank you for being interested...
> test any patch....
LiteRenderer...
> > I tried to hack the code... And it seems LiteRenderer is using
> Graphics2D for rendering maps...
> using drawString...
> > I didn't figure out the code responsible for draw
labels... but
> separately... and this bring the problem in...
right to
> alphabets...
> Ahmad,
a set
them to draw
fonts, but
giving up
> too much performance in the western case, but I'm not sure
about the
> results.
(attached to
this is fine?
> Cheers
> Andrea
</mc/compose?to=Geoserver-devel@lists.sourceforge.net>
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel-- Justin Deoliveira
Enterprise support for open source geospatial.------------------------------------------------------------------------
http://p.sf.net/sfu/sf-spreadtheword------------------------------------------------------------------------
Justin Deoliveira
