Hello …
I am new to Geoserver and OpenLayers … I am trying to develop a Map consisting of roads only …
Refer to the image … the image generated has white roads are coming above the brown roads .
But it should have been the opposite … so how to control the rendering sequence or there is some method through
which we can set this… .Please assist me in getting the desired output .
Thanks in advance
Best Regards
Harpal Singh
(attachments)
Hi Harpal,
The way to ensure a certain rendering order is by using separate
FeatureTypeStyle elements in your SLD. Put all the road outlines in a
separate FTS that occurs first in the document.
Hope that helps.
-Justin
On Thu, 15 Oct 2009 17:38:03 +0530, harpal singh <harpalhira@anonymised.com>
wrote:
Hello ......
I am new to Geoserver and OpenLayers .. I am trying to develop a Map
consisting of roads only ...
Refer to the image ...... the image generated has white roads are coming
But it should have been the opposite ..... so how to control the
rendering
which we can set this.... .Please assist me in getting the desired output
Thanks in advance
Best Regards
Harpal Singh
Justin Deoliveira
OpenGeo - http://opengeo.org
