[Geoserver-devel] Problem inserting empty/null geometry
I have a problem inserting empty or null geometries in PostGIS using Geoserver.
I have an Insert which contains something like
<test:table>
<test:somefield>value</test:somefield>
<test:geometryfield><gml:Point><gml:coordinates>1 1</gml:coordinates></gml:Point></test:geometryfield>
</test:table>
The example above works fine. However the geometry is not always given. When removing the <test:geometryfield> element or using an empty element like <test:geometryfield/> Geoserver throws a nulllpointerexception. Is it not possible to insert an empty or null geometry?
I encountered another problem when trying to insert a Polygon with an empty <gml:coordinates>. A GEOMETRYCOLLECTION(empty) is inserted into the PostGIS database. When Retrieving this value Geoserver throws another exceptions (TransformerException: Translator error and IllegalStateException).
Am I doing something wrong?
Thanks in advance,
Steven Fruijtier
It should be possible to insert an empty or null geometry (as long as the
backend allows it, which wouldn't be a null pointer if it was). Could you
send the stack traces, so we can see where the problem might be occurring?
Go ahead and file it as a bug in the task tracker
http://jira.codehaus.org/secure/BrowseProject.jspa?id=10311 And include
all the relevant information . geoserver version operating system, java
version, servlet container, backend database, and as much stack trace and
logging info as you can.
Chris
On Wed, 10 Nov 2004, Steven Fruijtier wrote:
<test:table>
</test:table>
Thanks in advance,
Steven Fruijtier
This SF.Net email is sponsored by:
Sybase ASE Linux Express Edition - download now for FREE
LinuxWorld Reader's Choice Award Winner for best database on Linux.
http://ads.osdn.com/?ad_id=5588&alloc_id=12065&op=click
Geoserver-devel mailing list
You may also wish to include your schema file (if you have configured
geoserver in this way).
David
Chris
> Hi,
> <test:table>
> </test:table>
> Thanks in advance,
> Steven Fruijtier
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
